I have a 998 with a accuspark electronic ignition conversion kit
I have wired the limiter as the picture attached shows ( only difference mine does not have the orange wire for the light)
Problem I'm having is once the limiter is installed. My mini will limit at 3,000 rpm. Obviously this is unacceptable.
None of the led's on the limiter light up & the minus & plus button do not seem to do anything.
Is there a special trick for this or can I assume its a dud ??
Many thanks
