A Reluctant Plea For Help (South Wales)
electrical
25 replies to this topic
#16 cal844
cal844
  • 9,736 posts
  • Local Club: TFMOC
Posted 02 April 2014 - 08:52 PM
Lube the starter up!
#17 Lloydc
Lloydc
  • Just Joined
  • 16 posts
Posted 02 April 2014 - 09:28 PM
It's well lubed! it engages fine, but disengages just before the engine takes over!
#18 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
  • Local Club: Surabaya Mini Club
Posted 03 April 2014 - 08:43 AM
Just the wrong thing to do - should be clean and dry only
#19 cal844
cal844
  • 9,736 posts
  • Local Club: TFMOC
Posted 03 April 2014 - 09:52 AM
I always clean my starters with a small amount of wd40, then remove the excess with a rag and reinstall. This way i get no sticking starters :)
#20 Lloydc
Lloydc
  • Just Joined
  • 16 posts
Posted 03 April 2014 - 10:19 AM
WD40d the bendix mechanism, Pinion gear is clean and free from dirt/grease.
Could the starter motor be at fault? not strong enough perhaps?
or would I be looking at a worn ring gear? :X
#21 coopdog
coopdog
  • 4,506 posts
Posted 03 April 2014 - 10:47 AM
hows your battery looking?
#22 Lloydc
Lloydc
  • Just Joined
  • 16 posts
Posted 03 April 2014 - 01:16 PM
Battery is dead flat, so have been jump starting so far.
#23 coopdog
coopdog
  • 4,506 posts
Posted 03 April 2014 - 01:48 PM
hmmmmmm
id try it with a full battery to be safe while jumping
#24 Lloydc
Lloydc
  • Just Joined
  • 16 posts
Posted 03 April 2014 - 02:22 PM
Will give that a go tomorrow! Thanks for the help so far!
#25 Lloydc
Lloydc
  • Just Joined
  • 16 posts
Posted 12 April 2014 - 10:38 AM
Ok Bit of an update...It's running!
Starter motor was fine, put a new battery, got some new oil in it and fiddled about with the carb + timing and she starts almost every time!
Only snag is it won't go into gear, but I'm thinking that's due to an old slave cylinder.
Thanks for the help, bloody brilliant :)
Chris
#26 coopdog
coopdog
  • 4,506 posts
Posted 12 April 2014 - 10:56 AM
Well done!
