Car Shutting Off At Random, Ignition Wiring Burning Hot
electrical engine
No replies to this topic
#1 oser1ww
oser1ww
    Starting My Mini Up
  • 1 posts
Posted Today, 04:17 PM
Hello everyone here, this is my first post after a decent amount of lurking.
I have a problem with my car, it keeps shutting off randomly, especially under load. I did make sure to read older topics and try them out, but to no avail.
My car is a 198X (post 1984) Mk4 998 fitted with a HS4 carburetor and has an aftermarket A/C put into it, though I am unsure how long ago was it installed.
I have noticed that the wiring from the ignition switch (brown, red/white, and the auxiliary green) also becomes extremely hot when the engine is running. So much so that it did smolder once under the dash during a test. After that I have decided not to use the car until the wiring issue is fixed.
The wires are equally as hot when the headlights/ aircon are on, as with only the engine running. Regretfully, I have not yet tested it alone with the ignition in the No. 1 or 2 position though. The wiring is in some areas a bit dirty, but the problem persisted even after cleaning with contact cleaner.
I did not that the battery has a failed cell in it (reading only 10.5, rather than the accepted 12.6V with the engine off, reads slightly above 12.7 when charging).
Thank you for reading.
Also tagged with one or more of these keywords: electrical, engine
