Delayed Power Response On 998 Mini
engine electrical
17 replies to this topic
#1 Ginge620
Ginge620
  • 86 posts
Posted 19 April 2014 - 10:36 PM
1989 998cc mini + HS4  + Stage 1 Kit + 99 Octane fuel
When i push the accelerator pedal i get around a 1 to 2 second delay before the power comes in.
When the engine is cold it is worse and it makes a burbling noise, more choke seams to help.
Happens all across the rev range.
Sometimes i get an instant response if i stay quarter to half throttle then go full.
An example of how this is annoying is when i exit a corner i have to plant my foot to the ground as i enter it to be able to accelerate out.
There is oil in the dashpot, im using 3 in 1 oil.
Timing is set to standard if anything a little bit more advance
Compression is 8.5 to 9 bar with a hot engine
Im using NGK BP6ES plugs
Distributor is fitted with electronic ignition
Edited by Ginge620, 20 April 2014 - 12:02 PM.
#2 Gremlin
Gremlin
  • 2,142 posts
Posted 19 April 2014 - 10:41 PM
Listen to the engine, instead of flooring it like in a modern car with electronics controlling everything, you have to tickle it :)
#3 Ginge620
Ginge620
  • 86 posts
Posted 19 April 2014 - 10:46 PM
If i go part throttle its the same. If i go to little it doesnt pick up.
Edited by Ginge620, 20 April 2014 - 12:03 PM.
#4 Gremlin
Gremlin
  • 2,142 posts
Posted 19 April 2014 - 11:00 PM
What carb spring have you got?
#5 robminibcy
robminibcy
  • 1,516 posts
Posted 19 April 2014 - 11:16 PM
I'd check your ignition timing and also that your vac advance is connected and undamaged. Mine had terrible flat spots despite a nice blue burn on colour tune, a quick fiddle by ear of the timing and instant pickup. Mine is adanced more now than specified but doesn't pink and much better than running on book figures.
don't forget that quoted figures are probably for lower octane fuels so that will make a small differance
Edited by robminibcy, 19 April 2014 - 11:26 PM.
#6 ACDodd
ACDodd
  • Mini Docs
  • 2,765 posts
Posted 19 April 2014 - 11:51 PM
Thicken up the carb oil. To engine oil. See if that improves it.
Ac
Edited by ACDodd, 19 April 2014 - 11:51 PM.
#7 minimuk
minimuk
  • 1,946 posts
Posted 20 April 2014 - 12:05 AM
A few things migt help,......have you checked yr Co2......, I second thicker carb oil,........ nd check for a vacuum leak, yr drawing false air in somewhere
#8 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 20 April 2014 - 12:26 AM
Correctly tuned, you should be able to floor the throttle in a Mini with no problems or hesitation.
#9 Gremlin
Gremlin
  • 2,142 posts
Posted 20 April 2014 - 06:52 AM
Yeah, but if he says oh it's trnasformed it, we can mention things like thicker carb oil
#10 coopdog
coopdog
  • 4,506 posts
Posted 20 April 2014 - 09:34 AM
GEt it on a rr
#11 Ginge620
Ginge620
  • 86 posts
Posted 20 April 2014 - 11:59 AM
Red for stage 1 998
http://www.minisport...tage-1-kit.html
#12 Ginge620
Ginge620
  • 86 posts
Posted 20 April 2014 - 12:01 PM
How did you time the engine by ear?
#13 Vipernoir
Vipernoir
  • 782 posts
  • Local Club: Minis Unlimited
Posted 20 April 2014 - 12:21 PM
3-in-1 is way too thin.
Like others have said, drain it out and refill with engine oil.
#14 robminibcy
robminibcy
  • 1,516 posts
Posted 20 April 2014 - 04:45 PM
turn the dizzy slowly listening to the engine speed, when it is at its fastest clamp the dizzy and readjust the idle speed on the carb
#15 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 20 April 2014 - 04:52 PM
My 998 was built in 1983 and I am still waiting for the power to kick in.
Also tagged with one or more of these keywords: engine, electrical
