1980 Mini1275 Gt - Aka The Tart
clubman
290 replies to this topic
#76 minimissions
minimissions
  • 3,427 posts
  • Local Club: M.M.O.C
Posted 27 April 2015 - 11:42 AM
Thats coming along nicely nice to see some new metal going in :) Love a GT.
#77 ger
ger
  • Just Joined
  • 233 posts
  • Local Club: M4 Minis
Posted 27 April 2015 - 04:01 PM
Ben_O - Not yet. That's the first thing thing I'm gonna do before welding up anything on the w/e.
#78 Toeknee
Toeknee
  • 59 posts
Posted 27 April 2015 - 06:11 PM
Ger, as your first 'proper' resto the progress you've made is even more impressive.  Keep up the good work :)
#79 mk1leg
mk1leg
  • 9,343 posts
Posted 28 April 2015 - 08:17 PM
Wow thats a Project......keep up the good work................. :highfive:
#80 ger
ger
  • Just Joined
  • 233 posts
Posted 02 May 2015 - 01:17 PM
Tried again today - a lot more fetling with the bottom of the flitches and now got this.
Used skinpins to slowly pull the panels together.
which gave me this on the inside.
Not perfect but a bit of dressing it should look ok.
Then trial fitted the doors.
So this is how she is after todays work. Panels off tomorrow and prep them ready for welding.
Ger
#81 ger
ger
  • Just Joined
  • 233 posts
Posted 03 May 2015 - 12:17 PM
Passenger side panels prepped for welding. They took a little longer than I'd thought.
Ger
#82 Guest_johnylässig_*
Guest_johnylässig_*
  • Guests
Posted 03 May 2015 - 01:18 PM
great job with these panels, looking forward to this
#83 alchall
alchall
  • Just Joined
  • 604 posts
Posted 04 May 2015 - 09:16 PM
Interesting to see how your flitch lines up with the toe board, looks exactly like mine, the two panels despite being heritage aren't quite the same shape and I'll be using similar tactics to pull them together as you have here on yours....
#84 ger
ger
  • Just Joined
  • 233 posts
Posted 05 May 2015 - 07:12 AM
Drivers side now prepped as well. Bit of welding next w/e.
Ger
#85 johnR
johnR
  • 2,322 posts
Posted 05 May 2015 - 07:05 PM
Ger
You're doing a really good job - you seem to have an impressive set of bodywork clamps - I imagine the right tools make the job easier.
Keep it up,
john
#86 ger
ger
  • Just Joined
  • 233 posts
Posted 21 May 2015 - 06:49 AM
Finally welded in the door post stiffners - after a bit more faffing about.
Passenger side inner wing back on and ready for welding as well.
Ger
#87 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 21 May 2015 - 07:53 AM
Very neat.
Love it :-)
Ben
#88 ger
ger
  • Just Joined
  • 233 posts
Posted 26 May 2015 - 06:43 AM
I've had a busy bank holiday w/e.
First off drivers side inner wing prepped for welding.
Plug welds done.
Welds cleaned up and a splash of primer.
Also did drivers side.
And as I was on a roll I also did the front x-member to wing brackets.
Ground down welds and more primer.
So now she looks like this.
Ger
#89 jim5570
jim5570
  • 19 posts
Posted 26 May 2015 - 08:30 AM
Wow,
That is really coming along nicely now. Should be on the road for Summer. It really is great to see this kind of work. You seem so methodical and precise. I think your GT should be stronger than when it came off the production line. Great work, keep it going.
James
#90 ger
ger
  • Just Joined
  • 233 posts
Posted 15 June 2015 - 06:35 AM
So this w/e I finally got her on the jig.
Finished off welding the bottom of the flitches to the toeboard.
Finished off with a splash of primer.
Then back to the routine of cutting more metal out in preparation of doing the floors when I order the panels in July.
Ger
Also tagged with one or more of these keywords: clubman
    Bing (1)
