Aasnes1`s 1977 Mini.
roundnose
160 replies to this topic
#76 MrIan
MrIan
  • 125 posts
Posted 30 January 2015 - 11:47 PM
Hi again, get your bodyshop to have a look or have a look yourself, on the underside facing the floor pan the sills should have slots in where the bumps are in the sill, these are the drain holes to let water n moisture out and also let air get in to help keep the box section dry, they might for now be able to drill holes and maybe open up the closed sills (if they are cover sills that is, but they sure do look like it). Oh and once again, nice looking mini there.
#77 Aasnes1
Aasnes1
  • 120 posts
Posted 31 January 2015 - 05:22 PM
I have the slots there, do i need to drill holes there, or are the holes in the slots big enough? We have some "stuff" at work that they use in cavities for rustproofing, its in spraycans with long noozles(don't know the name for it:p, they have great experience with using that:)
Sorry for my bad english..
#78 Vinay-RS
Vinay-RS
  • 2,115 posts
Posted 31 January 2015 - 05:26 PM
Nice work on the engine bay, The area cleaned up well and it looks like it was only surface rust. I think there is a thread based on what Mrlan was talking about: http://www.theminifo...-to-avoid-them/
#79 Aasnes1
Aasnes1
  • 120 posts
Posted 31 January 2015 - 06:42 PM
Yes, just surface rust, luckely:)
Here is a picture from under the car, think i dont have the closed ones?
Screenshot_2015-01-31-19-39-10_zpsm56ra3
#80 Vinay-RS
Vinay-RS
  • 2,115 posts
Posted 31 January 2015 - 06:57 PM
Hey man, I'd ask in the technical section about the sills, to get the best opinions.
#81 Aasnes1
Aasnes1
  • 120 posts
Posted 04 February 2015 - 07:00 AM
Ordered a set of 7x13 Superlites, love those wheels :)
1211_7x_13__JBW_Superlight_Silver_-_4x10
Yesterday i got the enginebay painted, and the result got alot better then i thought it would be! :)
#82 Vinay-RS
Vinay-RS
  • 2,115 posts
Posted 04 February 2015 - 07:10 AM
Nice work! Looks stunning :)
#83 Aasnes1
Aasnes1
  • 120 posts
Posted 04 February 2015 - 08:00 AM
Thank you! :D
#84 Aasnes1
Aasnes1
  • 120 posts
Posted 06 February 2015 - 07:36 AM
Fixed the wiring and changed the fusebox, probably need a new wiringloom, but for now it its going to be like this. The biggest glassfuses was 35Amp, and the biggest bladefuse i found was 30Amp, hope this will work!
sandblasted the brake/clutch cylinders and got them painted, not sure about how that will look, so if thay turn out very bad i have to buy some new ones :)
#85 GraemeC
GraemeC
  • 7,472 posts
Posted 06 February 2015 - 08:25 AM
Ther starter solenoid needs a good earth to its body - as standard this is through the fixing to the wing which I don't think i will get with your new paint and that self tapper.
I prefer to run a separate run earth to it from the main earth point near the inner wing brace.
#86 Aasnes1
Aasnes1
  • 120 posts
Posted 06 February 2015 - 09:22 AM
ok, thanks for the tips! going to run an new earth to it then! :)
#87 Aasnes1
Aasnes1
  • 120 posts
Posted 06 February 2015 - 03:11 PM
Instead of the painted brakelines, i polished up the copper, and wow! They turned out great!😀
#88 Vinay-RS
Vinay-RS
  • 2,115 posts
Posted 06 February 2015 - 06:30 PM
Once again, you are doing some excellent work on this. When you are done you should post a before and after pic to the engine bay styling section :)
#89 Aasnes1
Aasnes1
  • 120 posts
Posted 06 February 2015 - 07:43 PM
Appreciate it!
Yes, going to post a picture there when it's done!:)
#90 Aasnes1
Aasnes1
  • 120 posts
Posted 11 February 2015 - 07:43 AM
Engine is in! and without any scratches ;)
on the pictures everything is just temporarily in place, later today im going to get everything up and running, hopefully :)
