Properly Connect Water Heated Inlet Manifold Stage 1 From Minispare?
engine
13 replies to this topic
#1 Mienda
Mienda
    Starting My Mini Up
  • 2 posts
Posted 06 February 2016 - 10:40 AM
Hi !
I'd like to know where to connect the hoses number 9 and 10 on the attached file .
Is the inlet manifold need realy to be water heated ?
Every time I saw the mini spare stage 1 kit install the inlet manifold water hose were not plugged.
Do you have pict of a proper installation on the cooling system?
Did you notice any differences?
My 1990 mini 1000special with stage 1 and hs 4 carb works very well but maybe it could be better specially in winter?
#2 minifreek1
minifreek1
  • 1,260 posts
  • Local Club: S.U.N.M.O.C
Posted 06 February 2016 - 10:58 AM
The manifold doesn't have to be water heated, it can be blanked off...
The heated manifolds was originally introduced for the colder countried that the Minis/Metro's was exported to, so it could help with the carb to stop from freezing up...
In this country, that rarely happens...
#3 Mienda
Mienda
    Starting My Mini Up
  • 2 posts
Posted 06 February 2016 - 11:49 AM
Ok,
So I leave like that.
thank's you Very much !
#4 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 06 February 2016 - 12:13 PM
It's true that it's not absolutely neccesary to connect it up, but it I believe that it does more than just prevent carb icing. My understanding is that it heats the inlet to aid fuel atomisation and prevent fuel condensing on the inner inlet walls during cold conditions as well. The standard cast iron inlet is already heated by way of it bring joined:integral to the exhaust manifold, however as the alloy flowed versions are separate to the exhaust manifolds, they take much longer to heat up.
I have two 1275 minis both with similar stage 1 set ups, but one has the heated inlet plumbed in and one does not. The one with the heated inlet is noticeably smoother on startup over the winter months, but in warmer conditions there is no discernible difference between the two. Therefore having run both, my advice would be to plumb the heated inlet in if your mini is a year round daily drive, but not to bother if it's just a fair weather weekend toy.
#5 Ethel
  • 26,827 posts
Posted 06 February 2016 - 02:05 PM
Ditto,
The easiest option is to cut one of your heater hoses and connect it back together using the manifold. Just be aware Minis with the heater valve on the head used 1/2 inch bore pipe; the later ones with the plastic valve in the hose are 5/8ths bore.
I've no idea what size the pipes on your manifold are, the MG Metro version was 5/8ths.
#6 Anthony30
Anthony30
  • 1,467 posts
  • Local Club: N/A
Posted 06 February 2016 - 03:16 PM
I can't see a heated inlet manifold helping performance, IMO it would hinder performance. :shy:
#7 Ethel
  • 26,827 posts
Posted 06 February 2016 - 04:38 PM
Colder air is more dense, so yes being able to cram more into the cylinder would be good for performance. But, air isn't a good conductor , so if you've got the throttle wide open not much of the air will pick up any heat as it rushes through the manifold. When the throttle is less than wide open you're trying to restrict the amount of air going in to the engine anyway. Also, more air squeezes past the throttle plate at the top and bottom, which are typically the areas where the heater pipe is placed.
As Dave said, there'll be far more effect on any fuel that has condensed on the cold metal of the manifold and is pooling or running along it, instead of being carried in small, combustible) droplets in the air.
#8 Icey
Icey
  • 1,586 posts
Posted 06 February 2016 - 05:41 PM
 Common understanding would agree - keep heat out of the intake track at all costs. However...
Have a read of Vizards writings on the matter. One point he makes is that even without the water heating, on a hot day the intake will pick up heat from the air and exhaust raising it's temperature to similar levels anyway. So by plumbing it in you gain the benefits of better winter/cold performance with no/tiny affect on hot/summer performance.
I have ours plumbed in but part of that was because it provided a neat solutions to getting water out of the head and over the other side of the engine bay :lol:
Obligatory engine shot....
Ba2oIGR.jpg?1
#9 Anthony30
Anthony30
  • 1,467 posts
  • Local Club: N/A
Posted 06 February 2016 - 06:06 PM
Ba2oIGR.jpg?1
Sprintex? You posh sod!  ;D It looks neat, I'll give you that. :highfive:
Edited by Anthony30, 06 February 2016 - 06:06 PM.
#10 KanKanManKan
KanKanManKan
    Just On Tickover
  • 6 posts
Posted 11 July 2025 - 09:10 PM
Ba2oIGR.jpg?1
Can you share more details about the box where the thermostat is? Curious to know what this is and what it does
#11 Icey
Icey
  • 1,586 posts
Posted 11 July 2025 - 09:38 PM
Holy thread resurrection, Batman!
It was an ‘ultimate engine steady’. I only fitted it as I’d chopped off the original steady bracket as it was originally built for a Vauxhall engine.
This thread is so old that I don’t even have that engine anymore and have welded the original bracket back on!
#12 Cooperman
  • 23,569 posts
Posted 11 July 2025 - 09:40 PM
It’s an ‘Ultimate Engine Steady’.
#13 nicklouse
  • 19,067 posts
Posted 12 July 2025 - 11:18 AM
They were ultimate in the 80s but are crap and a pain in the arse, there are much better options available now.
#14 KanKanManKan
KanKanManKan
    Just On Tickover
  • 6 posts
Posted 17 July 2025 - 12:52 PM
Thank you for sharing this info. I was just curious as it looked after market
