Something's Fishy
electrical engine
16 replies to this topic
#1 hefner426
hefner426
  • 15 posts
Posted 20 June 2016 - 01:50 PM
Hey folks. I'm new to the mini world. I picked up a mini 25 a little less than a year ago from a German fellow. Said it hadn't ran in about 3 years. It took me a little while and quite a few dollars but it's on the road. I will be taking on the task of restoring this thing when I get back stateside. But I was just wondering if you folks could take a quick look at my pics and maybe help identify any issues. Just by looking at other minis it seems like my electrics are all wrong. I don't even know what 3 of the 7 switches on my dash do. Fuel needle doesn't work. Ithe drops rpms when the headlamps are on. Just to name a few. Thanks in advance!
#2 nicklouse
  • 18,679 posts
Posted 20 June 2016 - 01:54 PM
sounds like the battery is on the way out or the earth contacts are poor for one and the rest we will need the pictures.
#3 hefner426
hefner426
  • 15 posts
Posted 20 June 2016 - 02:04 PM
Here's a few to start
#4 hefner426
hefner426
  • 15 posts
Posted 20 June 2016 - 02:05 PM
The battery is still fairly new
#5 nicklouse
  • 18,679 posts
Posted 20 June 2016 - 02:12 PM
still get it checked.
at a guess it has an extra heater unit.
time to get tracing the wires as the switches could be for anything.
#6 hefner426
hefner426
  • 15 posts
Posted 20 June 2016 - 02:16 PM
I kinda figured it's been wired wrong all altogether. Pulled a flasher relay off marked with vw audi logos
#7 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 20 June 2016 - 04:02 PM
flasher relays are pretty universal
#8 Rocket.
Rocket.
  • 1,441 posts
Posted 20 June 2016 - 04:31 PM
That Coil fitment !
#9 nicklouse
  • 18,679 posts
Posted 20 June 2016 - 04:38 PM
And that red lever on a plumbers tap.
Looks like it has had spots on at some time or some such. Big red cable on left.
#10 Icey
Icey
  • 1,552 posts
Posted 20 June 2016 - 08:09 PM
I was thinking that could be a connection for a water heater, which I guessed could be the black cylinder if the car had been used in very cold regions.
#11 hefner426
hefner426
  • 15 posts
Posted 20 June 2016 - 08:39 PM
I can get some closer pics in the morning. Really had do idea what the red lever or the random red cable with plug were
#12 MiniMonty
MiniMonty
  • 1,802 posts
Posted 20 June 2016 - 11:34 PM
Those red plastic switched on the dash do nothing - they are just for fun.
Looks like it may have had an alarm (or such like) at some point and some groovy hi-fi but otherwise the electrics look standard.
Get it on the road and if it ain't broke, don't fix it   :D
#13 Ethel
  • 26,041 posts
Posted 21 June 2016 - 12:33 AM
Looks like that might be an electric water pump wired in under the bonnet, presumably so you can run the heater with the engine off, or possibly part of an engine preheater system??? (A very German thing if it's to reduce emissions and save fuel)
As it has a heated manifold, is the tap to isolate it, hard to see where it's tee'd of to if it doesn't do a U turn towards the manifold.
Batteries soon die if they're left flat, so if you don't know its history...
#14 hefner426
hefner426
  • 15 posts
Posted 21 June 2016 - 08:52 AM
The most I can figure is the 1st red switch is dash lights. 2nd is headlights but the 1st has to be on to work. 3rd is the grill lights. And 4th I believe is to the rear glass defroster
#15 hefner426
hefner426
  • 15 posts
Posted 21 June 2016 - 08:54 AM
Will it be an issue to rip that out of there? I doubt I will need being that I'll be close to Florida
Also tagged with one or more of these keywords: electrical, engine
