Posted 23 August 2018 - 08:35 PM
Posted 23 August 2018 - 08:36 PM
Was it raining when you drove it back home?
Posted 23 August 2018 - 08:47 PM
No it wasn’t raining
Posted 23 August 2018 - 08:56 PM
When you mean wont start, does it turn over?
Also, have you checked the earth strap connection?
Edited by WillCarter, 23 August 2018 - 08:58 PM.
Posted 23 August 2018 - 09:03 PM
Check for a spark
Check for any loose connections, unconnected wires
Check to see how dirty your air filter is
Make sure there isn't a blockage in your float chamber and fuel lines
Check the alternator is working fine
Make sure that your choke and accelerator cable is working properly
Make sure that your plug leads are all correctly connected
Check that your carb jet isn't stuck
Make sure there isn't any moisture in or around the distributor
Check the battery's voltage
Posted 23 August 2018 - 09:05 PM
pour some fuel down the carb intake ,if it starts more than likely fuel /pump problem
Posted 23 August 2018 - 09:10 PM
Check for a spark
No moisture in distributor
Got a new air filter to go on just didn’t do it tonight as I was getting eaten alive by mosies haha
Not too sure about the carb will have to have a look
Alternator and wiring are fine from what I can see
And I made sure the leads where all properly on when changing them
Posted 23 August 2018 - 09:12 PM
Might sound stupid but where is the earth strap on a mini?
Posted 23 August 2018 - 09:31 PM
It's a large threaded wire near to the engine steady:
http://www.theminifo...ngine-problems/
Haven't got a picture myself.
I don't know if the location varies depending on the model, but if you look for a large threaded wire like the one in the picture then you'll just need to follow it.
Then check the boot's earth connection too
Posted 23 August 2018 - 09:59 PM
Okay thanks will gives me a list of things to check over tomorrow I’ll let you know how it goes
Posted 23 August 2018 - 10:21 PM
Posted 24 August 2018 - 01:13 AM
Standard Points or converted to electronic ignition?
If points, have you checked to make sure they are correctly adjusted/gapped and checked the condenser.
Posted 24 August 2018 - 05:24 AM
Where are you based?
The isle of sheppey in kent
Posted 24 August 2018 - 05:26 AM
How can you tell like I said I’m new to all of this haha
Posted 24 August 2018 - 06:31 AM
check damper on top of carb
black screw down plastic cap on top of carb
unscrew and check it has oil
look inside it has another tube that one needs to be nigh full with oil.
only use 3 in one or light machine oil anything heavier will bog engine down
Mini Technical Sections →
Problems, Questions and Technical →
1966 Mini S - Clutch IssuesStarted by MBradbury73 , Today, 07:03 PM ![]() |
Ac Dodd TuningStarted by Kevybmini , 04 Jun 2025 ![]() |
Am I Missing Something?Started by Rubbershorts , 21 May 2025 ![]() |
About To Do A Horrible Job - Wish Me Luck And TipsStarted by floormanager , 01 May 2025 ![]() |
Which Idler Gear Bearing Is Correct?Started by JimmyStinkpickle , 28 Apr 2025 ![]() |
