Oil Leak At Distributor
engine
11 replies to this topic
#1 Chelsea_Pete
Chelsea_Pete
  • 66 posts
  • Local Club: London & Surrey MOC
Posted 05 November 2018 - 10:27 AM
As title suggest, I'm finding engine oil on the underside of my distributor body, dripping on top of the starter.
New distributor a few weeks back, leak started then. But doesn't seem to be coming from where the dizzy meets the block, rather the dizzy body itself.
I can make up a gasket for the distributor-block connection, but fairly sure this is not a normal place for one, right?! Since theres an oil 'O' ring on the spindle
In terms of engine oil pressure, I think its OK - breathers are clear, doesnt overheat, and if it was a pressure issue, I'd have expected it to burst out of the existing small leak at the gear rod selector seal!
Had a quick search of the forum and not found a thread on this leak point - is it common? Whats the best solution?
Cheers, Peter
#2 KTS
KTS
  • 2,490 posts
Posted 05 November 2018 - 01:00 PM
have you taken the distributor cap off and checked inside the distributor - clean or oily ?
there's lot of high pressure oil fittings around the distributor like oil filter feed pipe unions/oil pressure gauge/sensor fitting/pressure release valve that could leak and blow oil around that area
if you haven't already, give the whole area a damn good clean to help identify exactly where the oil is coming from
#3 Bat
Bat
  • 903 posts
Posted 05 November 2018 - 04:57 PM
Hi,
There shouldn't be any pressure behind the dizzy, so take a look at the things in the post above.
Cheers  :proud:
#4 Spider
  • 15,878 posts
Posted 05 November 2018 - 05:11 PM
Check the O Ring on the distributor body is there and hasn't gone hard.
If it is coming from the Distributor itself, then it's a possible sign that the bushes are worn.
A+ engines seem much more prone to doing this than the A types.
#5 Chelsea_Pete
Chelsea_Pete
  • 66 posts
Posted 05 November 2018 - 09:11 PM
Cheers guys, There's no oil at all under the cap, clean as a whistle.
As I say the distributor is brand new so Id doubt the seals or bushes are gone. Will try to get photos up tomorrow
Anyway, have worse issues to deal with as of this evening (towed home after coming off the road, oo-er!) so I'll have to go through the above check list at a later date, once Ive made sure all my stearing and suspension is still in order!
#6 cal844
cal844
  • 9,736 posts
  • Local Club: TFMOC
Posted 05 November 2018 - 11:10 PM
Hopefully for you the car isn't badly damaged.
My friend hit a deer once, we straightened the bonnet slam panel just enough to get the bonnet down and secure.
It's remained like that for 3years haha
#7 nicklouse
  • 19,067 posts
Posted 06 November 2018 - 12:00 AM
most likely getting splashed from the dip stick and the breathers are not connected to the carb/inlet.
#8 Verbree
Verbree
    Just On Tickover
  • 5 posts
Posted 06 July 2021 - 07:26 AM
Same problem on my Metro 1275 cc powered Mini. The oil even reached the clutch plate (following the starter motor body and flywheel housing) and made it slip!
The cause was radial play in the dizzy shaft. In my case is was 0.4 mm (0.016 thou). I reduced it to 0.1 mm (0.004 thou) using a shim at the base of the dizzy above the dog drive ring. Dry now and I am happy!
John
#9 Earley86
Earley86
  • 30 posts
Posted 15 August 2026 - 06:24 PM
Cheers, Peter
Did you ever solve this? Im having the same issues.
#10 Earley86
Earley86
  • 30 posts
Posted 16 August 2026 - 11:41 AM
So ive had another look at this today. I can move the shaft about 1/4 inch up and down. Im assuming the should be no vertical movement in the shaft.
Deffo time for a new one.
#11 68+86auto
68+86auto
  • 1,496 posts
Posted 16 August 2026 - 11:45 AM
It is normal to have some up and down movement. If it keeps coming up without a hard stop then it is a problem but it is a simple fix.
#12 Earley86
Earley86
  • 30 posts
Posted 22 August 2026 - 08:04 PM
Replaced the dizzy today the old one had alot of play up ans down and left and right. It was also showing signs of having oil inside it.
The new one is fitted and there is no more oil leaks. Hurrray.
Timed it to 9° btdc and all seems well.
