Which Oil Filler Cap For My Alloy Rocker Cover?
engine
16 replies to this topic
#1 LittleRedRocket
LittleRedRocket
  • 15 posts
Posted 28 April 2020 - 10:26 PM
Hello All,
I am 15 years old and have a 1979 Mini 1000 with a MG Metro 1275 engine. I have an alloy rocker cover that I would like to fit to my Mini. I have bead-blasted the rocker cover and have plans to paint it (See attached photos). I am unaware of the history of this rocker cover, but I need a oil filler cap before I fit it. I have looked on Mini Sport as well as, Mini Spares and Mini Mania, and I am not sure which cap, if any will fit. Does anyone know any history about this rocker cover and what oil filler cap will fit?
After bead blasting
Attached File  IMG_6003.JPG   38.34K   7 downloads
Before bead blasting
Attached File  IMG_4546_Fotor.jpg   61.43K   8 downloads
#2 nicklouse
  • 19,067 posts
Posted 28 April 2020 - 11:20 PM
Any will fit.
It it may have come with something special.
#3 LittleRedRocket
LittleRedRocket
  • 15 posts
Posted 28 April 2020 - 11:22 PM
Any will fit.
Notice how the lip is on the outside? A fuel cap almost fits. But most rocker covers have the lip/thread on the inside.
Edited by LittleRedRocket, 28 April 2020 - 11:32 PM.
#4 Bens mini 66
Bens mini 66
  • 30 posts
Posted 29 April 2020 - 12:06 AM
Do you have a cap you could try to fit onto it?
#5 LittleRedRocket
LittleRedRocket
  • 15 posts
Posted 29 April 2020 - 12:43 AM
Like I said, a fuel cap is close, but rocker covers almost always have the thread/lip on the inside so I don't have any that are remotely close.
Edited by LittleRedRocket, 29 April 2020 - 12:44 AM.
#6 LittleRedRocket
LittleRedRocket
  • 15 posts
Posted 29 April 2020 - 01:11 AM
Anyone have any ideas?
#7 Spider
  • 15,879 posts
Posted 29 April 2020 - 02:51 AM
It looks to me like it would take something in a similar style to a Radiator Cap, only bigger and suited to the job.
#8 GraemeC
GraemeC
  • 7,476 posts
Posted 29 April 2020 - 06:21 AM
That’s a nice HRG rocker cover, originally made for in-line A series engines (if it still had its original badge it would be backwards when fitted onto a Mini).
They originally had a cap made by a company called Ceandess. I think the caps are still available, but I’d need to ask some questions of a knowledgeable friend as to who makes/supplies them now.
Pm'd
Edited by GraemeC, 29 April 2020 - 08:32 AM.
#9 KTS
KTS
  • 2,490 posts
Posted 29 April 2020 - 07:05 AM
some background on HRG rocker covers below
http://mk1-performan....co.uk/hrg.html
#10 gazza82
gazza82
  • 3,100 posts
  • Local Club: TMF+
Posted 29 April 2020 - 11:55 AM
The breather pipe doesn't look original either .. looks more like 1/2" plumbing copper!
#11 LittleRedRocket
LittleRedRocket
  • 15 posts
Posted 29 April 2020 - 06:07 PM
Does anyone know if this cap will fit?
https://ceandess.onl...ck-019740010cab (of course without the dipstick)
Does anyone else have any other suggestions for a cap that will fit?
(and yes the breather is just 1/2" copper, it wasn't me though)
Thankyou everyone for your help!
Edited by LittleRedRocket, 29 April 2020 - 06:08 PM.
#12 KTS
KTS
  • 2,490 posts
Posted 29 April 2020 - 09:41 PM
That one looks to be 5.5" so probably a bit big.
What's the diameter of the neck on the rocker cover?
#13 LittleRedRocket
LittleRedRocket
  • 15 posts
Posted 29 April 2020 - 10:04 PM
Attached File  IMG_6121_Fotor.jpg   33.87K   1 downloads
Attached File  IMG_6122_Fotor.jpg   47.69K   1 downloads
Yep, way too big
Maybe this?
https://ceandess.onl...ick-05758000zkb
or this?
https://ceandess.onl...ted-0334200azfb
or other?
https://ceandess.online
#14 GraemeC
GraemeC
  • 7,476 posts
Posted 29 April 2020 - 10:14 PM
Most likely:
https://ceandess.onl...r-without-chain
but contact them with your pictures, they will advise exactly what to measure.
#15 brivinci
brivinci
  • 1,225 posts
Posted 21 October 2020 - 07:17 PM
This might day a day late and dollar short but I have a different period finned cover (like the standard alloy ones fitted to Metros) that uses a ceandess 02139000ZKB cap...at least that us what Katie over there told me. Same cap used on Triumph motorcycles. My rocker is vented as well and came with a non-vented cap. Not sure it matters unless you block off your vent on the cover...then you will need one in the cap.
