Piston Rings Identification
engine
4 replies to this topic
#1 MelvJ
MelvJ
    Just On Tickover
  • Just Joined
  • 6 posts
Posted 06 November 2020 - 01:24 PM
Hi everyone, good day all.
I own a Rover Mini 1.3 Injection model, its a red engine and it is a japanese model of 1994.
i am having troubles on identifying what are the piston rings used for my car when i attempt to make a purchase from minispares as for my restoration.
By any consideration or help, i really thank anyone who would help me show which is the piston ring set that fits my car according the stated specs.
#2 ACDodd
ACDodd
  • Mini Docs
  • 2,836 posts
Posted 06 November 2020 - 01:26 PM
http://www.minispare.../C1818.000.aspx
These should work. Check the side groove clearance before you buy new rings. If you can fit a 0.12mm feeler blade between the side of the ring and the grove in the top ring groove the pistons are junk.
Ac
Edited by ACDodd, 06 November 2020 - 01:28 PM.
#3 MelvJ
MelvJ
    Just On Tickover
  • Just Joined
  • 6 posts
Posted 06 November 2020 - 02:50 PM
Ac
yes noted that bro, but also the product link u gave doesnt seem to have any measurements. how do i check the side groove clearance as the measurements arent there
can i get more info please
#4 ACDodd
ACDodd
  • Mini Docs
  • 2,836 posts
Posted 06 November 2020 - 06:56 PM
Check with your existing rings. Those rings fit a 21253 piston which uses an r41570 ring pack which will also fit your pistons. If it does not, I’ll buy them off you!
Ac
Edited by ACDodd, 06 November 2020 - 06:58 PM.
#5 steeley
steeley
  • Just Joined
  • 623 posts
Posted 06 November 2020 - 07:19 PM
Give f.w. Thornton’s they should be able to help you
