Posted 05 December 2020 - 08:35 PM
I have an ongoing projekt of a 1974 mini 850 where i have some trouble getting the light to Work. The rear light function also when breaking but there is no light when the engine/iginition is on. I have the same problem with the front light, i only have the highbeam when i holding in and no regular lighting.
Are there any who knows what is up and can help a rookie?
Sincerely
Christian
Posted 05 December 2020 - 09:32 PM
Click the link below to see which fuse and circuits you need to check.
If you are struggling now
Change the switch, if that doesn't work try connecting a known working stalk into the connection at the steering column and work the stalk to see if anything changes.
Hope this helps.
https://www.theminif...a/#entry2766127
Also I strongly suggest buying a power probe, I don't know how I managed before buying this!
this is the one I have... There is a hard plastic storage box available separately for these but I don't know where to buy them.
https://gb-jbtools.g...QxoC6KIQAvD_BwE
Edited by cal844, 05 December 2020 - 09:33 PM.
Posted 06 December 2020 - 02:45 PM
Thank you - all of the fuses can actually rotatate independently of the glass, so i thinik i will start there.
Thank you for the fuse circuit - that is an amazing diagram!
Sincerely
Christian
Posted 06 December 2020 - 03:48 PM
Yes but if you remove the fuse and try to twist the ends against each other do they rotate? They shouldn'tThank you - all of the fuses can actually rotatate independently of the glass, so i thinik i will start there.
Sincerely
Christian
Edited by cal844, 06 December 2020 - 03:48 PM.
Posted 11 December 2020 - 07:37 AM
Posted 11 December 2020 - 10:10 AM
Mini Technical Sections →
Problems, Questions and Technical →
Misfire - Ignition Fault Or Fuel Problem?Started by derekaka2sheds , 01 Apr 2024 electrical, engine |
Mini Spi Charging IssueStarted by Dutch_MiniSPI , 27 Mar 2024 electrical |
Main Dipped Beam Not Working - Just Before Mot :-(Started by Park , 24 Mar 2024 electrical |
Speeduino EcuStarted by cooperpooper , 09 Mar 2024 electrical, engine |
Smiths Electronic Speedo Accuracy?Started by chuee , 01 Mar 2024 electrical |
