Slow Oil Refill
engine
14 replies to this topic
#1 Minicarter
Minicarter
  • 24 posts
Posted 25 January 2021 - 10:10 AM
Hello.
I have just replaced the head gasket on a 1275 Metro engine and when refilling with oil the rocker cover is filling up and it is taking about half an hour for it to drain down.
It has helped to turn the engine over by hand but is still draining very slowly. Also, it was very cold last night so the oil was very thick.
Is this normal?
The car has been off the road for nearly 5 years but prior to that I had replaced the oil several times before and don’t remember this being an issue.
Thanks.
#2 imack
imack
  • 2,382 posts
Posted 25 January 2021 - 10:35 AM
1275's can be pretty slow to fill with oil especially if you have cold 20/50 and a cold engine.
Only way to the sump is via 8 push rod holes which are already partially blocked with a push rod and then 2 holes circled to allow it to flow into the sump
#3 steeley
steeley
  • Just Joined
  • 623 posts
Posted 25 January 2021 - 10:37 AM
just be patient it will go in
#4 richmondclassicsnorthwales
  • 942 posts
Posted 25 January 2021 - 10:59 AM
The oil is slow to go down om a Metro engine, why ?
As well when you start it up, disconnect something so it does not start straight away - prime the oil galleries.
It may also clatter a bit, but does clear
#5 Dusky
Dusky
  • 5,322 posts
Posted 25 January 2021 - 11:16 AM
One of the reasons why 20w50 is far from ideal in an engine in winter.
#6 cal844
cal844
  • 9,736 posts
  • Local Club: TFMOC
Posted 25 January 2021 - 01:27 PM
Patience is key, it will take a while. Also when you come to starting the engine make sure it is out of gear and the clutch pedal up Before you crank the motor.
#7 KTS
KTS
  • 2,490 posts
Posted 25 January 2021 - 01:45 PM
keep the oil indoors to warm up before putting it in the engine - it'll flow a lot better when warmed.
#8 MiniMadRacer
MiniMadRacer
  • 906 posts
Posted 25 January 2021 - 05:50 PM
Pull the dip stick out....
#9 MiniMadRacer
MiniMadRacer
  • 906 posts
Posted 25 January 2021 - 05:51 PM
the air has to go somewhere as the oil drips down the tiny holes..air bubbling up through the oil to escape really slows things down
#10 Dusky
Dusky
  • 5,322 posts
Posted 25 January 2021 - 06:34 PM
Still have the breathers which connect through the outside air through the carb and air filter when the engine is turned off.
#11 Tornado99
Tornado99
  • 750 posts
Posted 25 January 2021 - 07:46 PM
Did my first mini oil change a few weeks ago, 1275 lump. Exact same issue filling 20w50. Oil was kept in heated room but was surprised how long it took to drain. So next time will try dipstick out and just be patient.
by the way, from videos ive seen on line of these oil changes, they never mention to prefill the oil filter prior to fitting to engine. This helps to get oil where it needs to go faster on initial start up, oil light goes out sooner.
Edited by Tornado99, 25 January 2021 - 07:47 PM.
#12 cal844
cal844
  • 9,736 posts
  • Local Club: TFMOC
Posted 25 January 2021 - 07:57 PM
Filling the oil filter is beneficial but on some cars (mini MPI as an example) has the filter horizontal so the oil would just leak out making a mess
#13 imack
imack
  • 2,382 posts
Posted 25 January 2021 - 07:59 PM
I always pre fill the oil filter and oil cooler.
Pulling the dipstick out doesn't make any noticeable difference to the speed of oil filling.
#14 MiniMadRacer
MiniMadRacer
  • 906 posts
Posted 25 January 2021 - 10:50 PM
I agree about the breathers, if they are ever cleaned.....
#15 Cooperman
  • 23,569 posts
Posted 25 January 2021 - 11:18 PM
If you don't prime the oil filter, or can't because the filter fits horizontally, take an ignition lead off and spin the engine over until the oil pressure warning light goes out. Whilst doing this do not push down on the clutch pedal.
