Mixing Pre A+ And A+ Final Drive
engine
4 replies to this topic
#1 mrmercisil
mrmercisil
    Just On Tickover
  • 5 posts
Posted 13 August 2021 - 02:58 PM
Hi guys, I have 2 diffs here and I was hoping to swap the crown wheel over onto the carrier in better condition.
The crown wheel (Pre A+) will go onto an A+ diff carrier. Are these 2 different types compatible?
Should I just be able to unbolt the crown wheel from one and use it on the other or will i have to use the planetary gears from the same set as the crown wheel? The pinion will be from the Pre A+ gearset as that is the gearbox it is going into.
Attached File  IMG_20210813_125649.jpg   68.15K   0 downloads
#2 GraemeC
GraemeC
  • 7,476 posts
Posted 13 August 2021 - 03:07 PM
It'll swap over fine.
You'll need to remove the bearing first, at which point you might need a new one....
#3 mrmercisil
mrmercisil
    Just On Tickover
  • 5 posts
Posted 13 August 2021 - 03:12 PM
Great thanks I'll get on that tomorrow and order a couple of new bearings!
#4 Ethel
  • 26,822 posts
Posted 13 August 2021 - 04:24 PM
I think as long as you keep the crown wheel & pinion as a pair you'll be fine
#5 mrmercisil
mrmercisil
    Just On Tickover
  • 5 posts
Posted 13 August 2021 - 05:33 PM
yeah they are from the same gearbox, so should be all good there. Cheers!
