Su Carb Backfiring/spitting Fuel
engine
16 replies to this topic
#1 Adge456
Adge456
  • 49 posts
Posted 25 July 2026 - 03:24 PM
Hi all,
Trying to get my Austin Mayfair stated after 6 years. It had a blown head gasket. I have replaced this and had a few niggly issues with an electronic distributor so reverted to new points. I have got the car running however it is spluttering fuel out the air intake of the Hs4.
I have managed to get the distributor to 4 degrees as it was very advanced but the problem is persistent.
There is also exhaust gas by the looks of it coming from the intake.
I did the tappet adjustments following a tutorial and I know I have to get the car to temp and then re-torque but I don't want to run it too long with this issue.
Any advice would be much appreciated.
I will try to answer any questions to diagnose this.
Thanks a ton.
#2 lsto
lsto
  • 718 posts
Posted 25 July 2026 - 05:28 PM
Are the HT leads on the correct plugs? No1 cylinder is the timing chain end and the dizzy spins anti-clockwise, it's easy to get them in the wrong order.
#3 Adge456
Adge456
  • 49 posts
Posted 25 July 2026 - 05:50 PM
Yeah, just double checked. Got them going 1, 3, 4, 2. Anti clockwise
#4 Adge456
Adge456
  • 49 posts
Posted 25 July 2026 - 06:21 PM
Thinking about what I have just posted, could this be a result of a poor tappet adjustment job?
I may go through it again and see what it is like?
#5 Spider
  • 15,817 posts
Posted 25 July 2026 - 07:21 PM
It's typically from a lean mixture.
#6 Adge456
Adge456
  • 49 posts
Posted 26 July 2026 - 11:28 AM
Had a look at the tappets and exhaust on cylinder 1 was way out of spec. Don't think I tightened it and it's worked itself loose. I have just eyeballed it for now, done a quick 30 second start and didn't see any fuel or exhaust smoke.
I will set the fuel mixture and go through all of the clearances and hopefully this works.
#7 68+86auto
68+86auto
  • 1,450 posts
Posted 26 July 2026 - 11:57 AM
Can you post some pictures of the engine bay, especially some showing the carb, distributor and plug leads.
#8 Adge456
Adge456
  • 49 posts
Posted 27 July 2026 - 07:20 AM
The tolerances was the issue. It's running fairly smooth now. Exhaust on cylinder 1 was very loose. I don't think I tightened it fully when making the adjustments and it must have worked it's way loose.
Now onto the next issue. The clutch seems seized. Hopefully just the slave.
I will be moving house in the coming months so my aim is to drive the car to the new property. Nothing like a deadline to give you motivation.
Once I have moved, I'll be looking to do a more thorough restoration
#9 sonscar
sonscar
  • 3,241 posts
Posted 27 July 2026 - 08:43 AM
The plunger on the wok can seize if left for a time,lube it and work it a bit.Steve..
#10 Adge456
Adge456
  • 49 posts
Posted 27 July 2026 - 12:46 PM
Yeah I think that is the issue. I disconnected the slave and that moves freely. I've put a bit of WD on the plunger and not much. Added a bit of 3 in 1 and managed to get a little movement so hopefully that will be enough for it to penetrate.
Would you suggest a few light taps or get a bar in there and work it back and forth?
#11 Designer
Designer
  • 756 posts
  • Local Club: LSMOC
Posted 27 July 2026 - 06:23 PM
Hi,
PlusGas is much better than WD40 as it is a proper penatrating fluid. I beleive WD40 is not classified as a penatrating fluid but more a water repellant.
Paddy
#12 Cooperman
  • 23,562 posts
Posted 27 July 2026 - 07:38 PM
Check the flexible hose from master cylinder to slave cylinder. I had a stuck clutch recently and after fitting a new slave and master cylinder, I changed the hose and it was that which cured the problem.
#13 Adge456
Adge456
  • 49 posts
Posted 28 July 2026 - 09:27 AM
Thank you, I need to order some proper penetrating fluid (something that should be in the garage anyway) so hopefully that will work.
I kept the slave on the hose but removed the pin to the clutch linkage and it moved freely so I do think it's the plunger.
#14 Adge456
Adge456
  • 49 posts
Posted 28 July 2026 - 12:33 PM
This is currently how it is seized.
No amount of swearing is helping..
Edited by Adge456, 28 July 2026 - 12:33 PM.
#15 Designer
Designer
  • 756 posts
  • Local Club: LSMOC
Posted 28 July 2026 - 02:51 PM
Hi,
Looking at your picture there should be a 6mm gap between the wok and the righthand of the two nuts below the clutch lever.
I do not know if not having that gap will mean the arm will not move but I am sure someone else will be able to clarify that.
Paddy
