First Car Resto
379 replies to this topic
#241 CanadianMiniFan
CanadianMiniFan
  • 1,591 posts
Posted 01 October 2009 - 11:44 PM
right, i've got the paint sample, looks great. i've been sanding and sanding and sanding, and thats just the inside so far haha, still got the engine bay and boot, but i'm going for the best finish i can get bymyself. i'll be p icking up the paint soon, and learning how to paint a car!
#242 CanadianMiniFan
CanadianMiniFan
  • 1,591 posts
Posted 21 October 2009 - 01:46 AM
Alright you could say i've had a bit of progress....
i painted the interior, engine bay and trunk myself. and that went alright, except i did it in halves, the trunk and rear at one time, front and engine bay. unfortunately, i changed primers for the front, and it gave a shitty finish to the paint, very dry. so i'm going ot clear coat the upper dash rail, and engine bay, so it looks decent. the rear look fab, the floors and back seat have primer overspray tho >_< the parts you see, the pockets, b pillar etc are good tho. annnd i took out the steering column and pedal box, as well as the steering rack. painted all those things. undercoated the whole bottom, as well as running the fuel and brake lines from the back. and I put up the front and rear subframes, looks great.
#243 CanadianMiniFan
CanadianMiniFan
  • 1,591 posts
Posted 25 October 2009 - 01:18 AM
so i sanded down the upper dash rail and crossmember, and re clear coated them. they look really good now. aaaand i reassembled the pedal box, all nice and painted, same with the steering column. i pulled the wiring through to the back, and into the engine bay. i'll probably put in the box and column on monday, and i have to make my nice new steering wheel fit. well, its not new, but i like it haha. oh and i got a steering drop bracket, figured nows the time really. eventually i'll have to make some brackets for the race seat to fit, and i'll set up the steering, and seat for best driving position.
#244 CanadianMiniFan
CanadianMiniFan
  • 1,591 posts
Posted 27 October 2009 - 11:32 PM
pedal box and steering column are in, so thats great. heres some front subframe pics.
#245 CanadianMiniFan
CanadianMiniFan
  • 1,591 posts
Posted 03 November 2009 - 02:58 AM
I got a bit more done today, drilled out a broken bolt/captive nut by the fuel tank strap, in the trunk. thats done now, i'll have to use a regular nut tho.
#246 mad4mins
mad4mins
  • 1,396 posts
  • Local Club: WAMO!
Posted 06 November 2009 - 05:56 PM
its coming along nicely!! like the grey colour nice and different!
goes well with the black.
#247 CanadianMiniFan
CanadianMiniFan
  • 1,591 posts
Posted 08 November 2009 - 06:45 PM
yeah the sides of the engine bay are a bit pale/dull/primer-esque, but the firewall, and parts of interior taht are visible got clearcoated and are good. i've got the master cylinders in and connected to the pedal box, had to make gaskets, probably took longer than the installation. my spax shocks were dark green, i don't know why, they are brand new Krypton gas ones....but green? so i painted them yellow haha. dont worry, i took off the sticker and re applied it. thats a bit of progress
#248 CanadianMiniFan
CanadianMiniFan
  • 1,591 posts
Posted 11 November 2009 - 03:51 AM
Got a bit more done, all the brake lines are now fitted up, i'll bleed it all tomorrow, hopefully no leaks! i got the handbrake lever installed and connected the lines. also put in the throttle pedal, and seatbelt brackets. heres a few pics.
the pics show no lines, that happened yesterday haha
#249 CanadianMiniFan
CanadianMiniFan
  • 1,591 posts
Posted 14 November 2009 - 02:56 AM
I've got the car bled, broke a valve on the front left caliper, and had to stop a few leaks. all good now!!! i rebuilt the wiper motor, looks good, hopefully works well too! things are going, next job is the instruments i suppose.
#250 CanadianMiniFan
CanadianMiniFan
  • 1,591 posts
Posted 14 November 2009 - 09:42 PM
today i cleaned up the instrument binnacle, took out the intrusments and did what i could with them as well. it looks pretyt good now! started wiring it up. then realized i needed a voltage stabilizer, some extra wires and sealent around the edge. well, ill know how to do it monday haha. also taped up the whole harness wiht black electrical tape. better than the ratty grey stuff it had.
#251 CanadianMiniFan
CanadianMiniFan
  • 1,591 posts
Posted 17 November 2009 - 02:03 AM
binnacle is bolted in, goopy stuff around it. good stuff i guess, got the voltage stabilizer hooked up as well as sorted out what wires where. noticed a wee bit of fluid around a brake fitting, i cleaned it off, and i'm hoping it was from a leak we had before, and it goes away, if not, we'll have to grind down the top of the braided hose fitting, as the metal pipes fitting might not be going down far enough, because its full tight. ho hum.
#252 CanadianMiniFan
CanadianMiniFan
  • 1,591 posts
Posted 24 November 2009 - 11:48 PM
So, i'm waiting on the pictures, but, the engines in!!!!! driveshafts connected, poly crosses rather than rubber. got the Y pipe on the LCB, that took ages, and alot of beating. also got the remote shift linkage hooked up. hmmmm what else. i dunno, i guess you'll see when i get the pictures!
#253 WillMini
WillMini
  • 191 posts
Posted 25 November 2009 - 03:40 AM
looks great! its like putting together a giant model
#254 CanadianMiniFan
CanadianMiniFan
  • 1,591 posts
Posted 26 November 2009 - 02:44 AM
Theres the engine going in, its in now, manifolds, y pipe, shift linkage and carbs are all on it now, aren't in the picture. i've got the slave cylinder spring installed, took a bit of time, and i've just started trying to do more little things. its sitting a bit high, and it doesn't have brand new cones or anything...so i did the right hting and ordered some hi los :D will look good anyways. i'll set the toe and such as well when i install those!
this is just a shot of the parts inside the car, many more not in it!
#255 CanadianMiniFan
CanadianMiniFan
  • 1,591 posts
Posted 27 November 2009 - 02:30 AM
Got a bit more done today, the clutch works properly now, the solenoid is hooked up, painted of course, battery cable run down the bottom and fixed in position, collecting some more small bits, cables and grommets and the like. getting closer and closer to starting the engine in the car.
