My Sprite Pocket Rocket
#46
Posted 14 August 2005 - 01:57 AM
#47
Posted 15 August 2005 - 10:46 AM
in the meantime..
#48
Posted 15 August 2005 - 11:30 AM
#49
Posted 15 August 2005 - 12:57 PM
#50
Posted 13 September 2005 - 10:27 AM
took thurs/fri off last week. only managed to replace one side of the front suspension thanks to corroded/seized parts.
i now have very little skin left on my knuckes.
drivers side gaz shock, coil spring and hi-lo fitted, with new knuckle.
solid subframe mounts fitted (that was fun)
removed tie rod and started trying to remove lower arm (seized on).
started passenger side, need to remove radiator to drop the top arm out so i can remove the old donut.
some pics to follow..
#51
Posted 13 September 2005 - 10:31 AM
primary gear bush and passenger side driveshaft seal.
joy.
#52
Posted 19 September 2005 - 10:56 AM
springs, hi-lows and dampers fitted. solid front subby mounts on. passenger side tie rod and lower arm fitted. NOTE: Minispeed "Ultimate" lower arms need some modding to fit with KAD tie rods.
piccies!
KAD rose jointed tie bars, Minispeed "Ultimate" rose joined lower arms
GAZ adjustable damper
solid mounts
BOING!
and finally some updated pics of the interior
sorry 56k'ers :fear:
#53
Posted 19 September 2005 - 11:17 AM
#54
Posted 19 September 2005 - 06:27 PM
how hard was removing the old suspension and fitting the new set
#55
Posted 19 September 2005 - 07:06 PM
#56
Posted 19 September 2005 - 11:05 PM
#57
Posted 20 September 2005 - 07:58 AM
rear suspension = easy
front suspension = pain in the behind
rose joints dont have bushes, thats why they make for better handling. although they do wear out quicker.. in that pic there are 2 spacers either side of the lower arm rose to stop it moving, although you cannot see them.
#58
Posted 20 September 2005 - 11:08 AM
#59
Posted 03 October 2005 - 10:16 AM
otherwise, everything is boxed up ready for the move into our new home
edit: oh and i have a new working handbrake now too. that was fun fitting that..
#60
Posted 04 October 2005 - 08:56 AM
The suspension setup looks awsome!
