Flubber!
#106
Posted 26 April 2007 - 09:35 PM
#107
Posted 26 April 2007 - 09:46 PM
1380, pulls a train from ideal... thats my kinda engine
#108
Posted 26 April 2007 - 09:50 PM
#109
Posted 26 April 2007 - 09:59 PM
I REALLLY REALLLLLY want a 1430 or 1480 - but its a road car... so have to look at reliability at the end of the day...
#110
Posted 28 April 2007 - 10:16 PM
#111
Posted 29 April 2007 - 08:04 PM
The 998's are also indistructable, im still to find someone who has destroyed one whilst driving!!
Hi, my names Jack
#112
Posted 29 April 2007 - 08:27 PM
It'll certainly keep the thread bumped up1.6 is the way forwards... apart from the daily re-builds and week long block lifespan
I think I should stick to 1380, it costs a lot to get my crank done - then I have to find some S rods...
#113
Posted 29 April 2007 - 09:51 PM
When I travel along, I can hear a "Whirly" noise, and its louder n louder, the fast I go... so looks like I might be replacing wheel bearings before Rivi Run....... Nice....
#114
Posted 29 April 2007 - 10:23 PM
#115
Posted 29 April 2007 - 10:26 PM
#116
Posted 30 April 2007 - 08:51 PM
Was alot easier then I thought, I also had to change my ball joint while I was there too...
Roll on Rivi Run now... then after, is when the hard work comes in!
#117
Posted 30 April 2007 - 09:01 PM
#118
Posted 30 April 2007 - 09:05 PM
Full strip down of the rear subframe, rebuild with new brake lines, new radius arms, new built up back plates, new shcoks, new Hi-Los, new cones, nice lick of paint, bolt all back together with new bolts...
Should handle a bit better then
Once thats done, I'll focus on the paint work, n body work, then I'll build a spare front subby I have here, and shove my 1380 into it, then swap it all over
#119
Posted 01 May 2007 - 08:09 PM
1380cc
1.3 Forged Cooper S rockers
Rob Walker stg4 head, 37in 32ex, 22cc Combustion Chambers, this head helped produce 112bhp@wheels, with a 286 on a 1380...
Hi-lift followers (making 1.5:1 rocker movement)
SW5-07 Camshaft
Powermax 7cc Dished pistons (73.5)
Balanced A+ rods
Glacier bearings
NEW 1275 A+ Crankshaft (Balanced)
Refurbed A+ Gearbox, 2.9 final Drive
Standard Transfer Gears
Lightened (11lb) Flywheel
Pre-Verto Clutch setup (Orange plate)
Recondition Pre-A+ Dizzy, with leccy points conversion
Swiftune Billet Oil Filter housing
Small Oil cooler contected to a Oil Thermostat
2core Rad
New large cast impeller water pump
Metal 6 blade fan
Twin HS4 Carbs, with K&N Cone filters (With Rampipes if they fit)
Standard 1275 Full Pump, with a turbo regulator
Should pull like a train, aiming for 100lb+ of torque, before 4-5K rpm...
#120
Posted 16 May 2007 - 09:39 AM
feel the van love juice floooooow!!
