Too right!! But then this is the wrong section for those engines, you need to be looking in the Projects section named 'Minis with engines for men' aka Non-Mini engined.1.6 is the way forwards... apart from the daily re-builds and week long block lifespan
>_<
Flubber!
#121
Posted 16 May 2007 - 10:11 AM
#122
Posted 16 May 2007 - 10:32 AM
I got VERY tempted to shove a K-Series into it... But I am drawing plans atm, to fit a small front mounted rad (old heater matrix) plumb it in, and fit a Mk5 inner wing fan (which I've been given) going over the orginal rad... so in affect, I'll have 2 rads, one sat up front, which will only be any good at speed, whereas the other will be there as the normal rad is....
But no, it has to be an A-Series, the Van is too rare, too speshul to ruin like that! - after all, the misses will kill me if I did it to the Van...
But for next years rivi run, hes going to be going over the fence, and dressing up... more to come of that yet
Edited by Ðogmatix, 16 May 2007 - 10:37 AM.
#123
Posted 16 May 2007 - 11:10 AM
Looking good by the way! I saw it loads at Riv Run but didn't actually realise it was yours.
#124
Posted 16 May 2007 - 11:23 AM
mrs bungle has a 998 and its never got anywhere near to runing hot
#125
Posted 16 May 2007 - 11:27 AM
I spent about £130 getting to the way it is now.... Next idea is the try more anti-freeze, as I am running a 30/70 mix atm, so might strenthen it to 50/50...
And Tom, thanks for stopping behind me on the motorway - just in case I broke down, but I was waiting for someone.....
#126
Posted 16 May 2007 - 07:51 PM
No worries about stopping, never like to see a Mini stopped on the hard shoulder so I always stop if I can! I realised you were waiting after you'd been stopped for a minute and didn't get out
#127
Posted 16 May 2007 - 09:13 PM
Well I replaced the 'stat when it was all apart...Oh right, sounds as if it could be something a bit more complex then, possibly mixture? timing? Thermostat? Just to state the obvious if you haven't already sorted it all!
No worries about stopping, never like to see a Mini stopped on the hard shoulder so I always stop if I can! I realised you were waiting after you'd been stopped for a minute and didn't get outThere were a few on the actual Riv Run as well but they were all terminal things like fans shredded and stuff.
I think the next thing it can be is timing and tuning... I know its slightly rich, but I see it a bit pointless getting a Rolling Road sess, as the 1380 will be going in soon....
#128
Posted 16 May 2007 - 10:45 PM
neil said it was the design of the pressed grill not giving good/adiquate air flow
#129
Posted 31 May 2007 - 10:10 AM
Fitted an oil pressure gauge, and I tapped the dizzy - moving it off whre it was... now I think the point are loose, and thus not giving the correct spark...
So I've got that to fix, and I'm tempted to get another rear subframe to build up, as half the stuff off the one that on him now, needs replacing....
#130
Posted 31 May 2007 - 10:28 AM
#131
Posted 31 May 2007 - 12:42 PM
Flubber isn't well
Are you still going to be alive on msn whilst you take a holiday from TMF??
#132
Posted 31 May 2007 - 12:52 PM
I might of finally blown a hole, who knows... the symptoms are, VERY VERY loud pinking, reluctant to rev - well when it was running... tried starting it yesterday, and the darn thing turns over ok, goes to fire, but nothing...
I'm going to swap the dizzy's over, as I have a recon'd leccy one in the shed, shove it on, if I still have problems, then off comes the head... If it all proves ok, and while I am there, I might shove some pockets into the block, and shove my '940 head on, then off to rollers at some point....
#133
Posted 31 May 2007 - 12:53 PM
Brakes are 100kg higher in stopping power than whats required
#134
Posted 31 May 2007 - 10:08 PM
you have a piston down.
#135
Posted 31 May 2007 - 10:12 PM
It seems to run ok, but its VERY lumpy (I do have a video I need to up load) the compressed gases, are coming back though the carb! I had a lick of flame now n then!!
All this because the dizzy moved less than half an inch!!!!
