My Mini ;) The First Chapter.
#1216
Posted 27 May 2009 - 09:01 PM
great project! sounds like its gonna be a stonker when its done! i like early minis!
Ed
#1217
Posted 27 May 2009 - 09:33 PM
Take your starter motor off (if you haven't already) and jam a screw driver or something similar in to the flywheel teeth, it'll lock the engine so you can undo the nut. Be warned, you will need to torque this back up to the correct value when you put it back on, same for the timing cover bolts
#1218
Posted 27 May 2009 - 09:34 PM
#1219
Posted 27 May 2009 - 09:47 PM
#1220
Posted 27 May 2009 - 09:51 PM
Might get the timing cover sandblasted when I get the other parts sandblasted, along with some other engine bits.. like those two caps, one has a breather on.. name?
#1221
Posted 27 May 2009 - 11:10 PM
#1222
Posted 28 May 2009 - 08:23 AM
I believe the wheel you're talking about is called the bottom pulley, and that bolt is threaded in to the crank.
Take your starter motor off (if you haven't already) and jam a screw driver or something similar in to the flywheel teeth, it'll lock the engine so you can undo the nut. Be warned, you will need to torque this back up to the correct value when you put it back on, same for the timing cover bolts.
Best thing to stop the flywheel going round is a piece of ring gear where the starter motor goes (one of dad's useful tips lol). That's if you have some spare ring gear hanging around. If not, then like deathrow said, use a screwdriver, pry bar or something of that description.
#1223
Posted 28 May 2009 - 08:27 AM
#1224
Posted 28 May 2009 - 09:16 AM
#1225
Posted 28 May 2009 - 12:10 PM
Although now I have a set of main bearings to use
Image, the things on the back (one has a breather), they're tappet chest covers chap
#1226
Posted 28 May 2009 - 12:17 PM
and dont do a SFM or it will end in Tears
Well atleast you can make fun of yourself, good too see that there are still people out there who don't take everything to heart.
Cars coming along nicely, goold luck finishing it.
Ben
#1227
Posted 28 May 2009 - 02:06 PM
Uploading far too many pictures now, I got a bit shutter happy
#1228
Posted 28 May 2009 - 03:15 PM
First of all the timing cover came off..
The state of the cover, will be sandblasted and possibly powdercoated depending on the price..
Some yummy pictures of the chain..
Then I touched up a few areas with paint and started adding on my new gaskets & bits..
Fuel pump before & after cleaning..
Back on the engine, along with the new speedo cable & gasket.
& how her heart stands now
#1229
Posted 28 May 2009 - 03:25 PM
I trust that motor is a good runner and doesn't need a full rebuild then?
#1230
Posted 28 May 2009 - 03:31 PM
Well she never missed a beat whilst she was on the road before, things like the cooling system broke down & occasionally the electrical bits but she's always performed well so it didn't make sense to rebuild it fully.. although I will be adding the rest of a stage 1 kit and get her rolling roaded before the MOT.
Bing (1)
