But am i getting it straight - if i have two cars - use the shell of one and the running gear off the other - as long as at the end i use the reg and log book etc from the car with the shell then i am ok? But if i use the reg and logbook from the car with the running gear then im being naughty?
In which case, it sounds like all this dude has got wrong is he shoulda advertisede as "Well its basically a 199X MPi BUT it has had everything changed to Mk1 spec" and then he shoulda used the reg from the 199X car?
In a nutshell, yes. Then all the guy has to do is transfer the reg number from the the Mk1 to the SPI so the V5 shows the details of the SPI with a cherished transfer reg number. And he may well have done that.
Thats the only issue as far as I see it. The guy may or may not deserve a slating as we don't know what he's told DVLA. But he does appear to be honest and up front about how he has built the car.
In any case, this thread has been useful as its highlighted the legalities of reshelling a car - a common Mini issue.
Retaining the original registration - the Points System
If a car is rebuilt, it must retain a certain amount of its old (pre-rebuild, not necessarily original) parts to retain its identity. This is calculated on a points system, whereby retaining the original part or system accrues points as detailed below. **Eight** points are required to retain the identity of the car.
Bodyshell* 5 points
Suspension 2 points
Steering assembly 2 points
Transmission 2 points
Driveshafts 1 point each
Engine 1 point
* The original unmodified bodyshell, or a new bodyshell of the same specification as the original supported by evidence from the dealer or manufacturer (e.g. receipt)
If a second-hand bodyshell is used, the vehicle must pass a single vehicle approval (SVA) test after which a "Q" prefix registration number will be allocated.So if you use any second hand bodyshell, second hand being deemed as a shell that has not been sold to you directly by a BMH approved dealer - this will include a shell from ebay (even if its brand new) then the car will have a Q registration. Even if everything from the old shell is moved over it stilll has a Q plate.
If you take a 1999 MPi put all the bits from a MK1 on it then using the points system above if you have enough of the orignal car then you can use the orignal MPi registration, if you dont have enough points then you have a Q plate issues after an SVA test.
What you can not do is move MK1 parts accross to an MPi and use the MK1 registration, this is what this guy is doing. You can see its more MPi than MK1 - he could put the MPi registration on it but no way could he have the MK1 reg.
Russ, as a concerned member of the public, and you an officer of the law, I would like you to officially investigate this and get to the bottom and finally acertain if there is any wrong doing
