looking good! engine looks way better.
Project Checkmate....
#61
Posted 05 May 2013 - 08:57 PM
#62
Posted 05 May 2013 - 08:59 PM
Cheers tom, yeah think i'l give it a new coat possibly but im side tracking again *tut tut*
#63
Posted 05 May 2013 - 09:03 PM
i would paint it now as will be hard when front end is fitted? can allways wrap the engine up to stop the bodywork dust and etc getting over it. you going to be painting it yourself to?
#64
Posted 05 May 2013 - 09:07 PM
Yeah good thinking, still needs a tart up at the side & starter, dizzy taking out as access is tricky.
Might just do that, yeah ofcourse i'l be doing it haha & probably brush paint.
Anyone know of a similar yellow to original 998 ?
#65
Posted 06 May 2013 - 09:02 PM
DAY 7
Hello hello hello
So today i thought id better get doing some panel work so i started by removing the under scuttle gusset to inspect the rusting woes.
The scuttle was ok on the corners but the middle & bulkhead need work all along so chop chop (happy now you,ve jinxed me sonikk
haha joking
This is how the day started:
So i first made a start on making a blanking plate for the freshair vent hole thats in the inner wing, this will be a test area when i get the welder running right:
Bye bye scuttle R.I.P.:
Next on the list was to peel back the front of the oversill:
Not good
Top class welders work haha:
Heater out:
Now for the shiney expensive stuff, new gen scuttle & top dash rail dry mock up:
Cya
Cliff
#66
Posted 06 May 2013 - 11:04 PM
yeh let me no how you get on if it works. ile do it.
Just starting this as we speak
, got the foil shaped & testing sooooon.
#68
Posted 10 May 2013 - 08:52 PM
Day (blah......) :
So past couple days weathers been crap but managed to sneak a few hours work here & there.
Dash & wheel off:
Had a look at the door bottoms:
Gave the bonnet a quick clean up as it turned my hands black everytime i lifted it off:
Also got a start on using a welder again:
Both flitch repairs done & zinc primed:
Bulkhead primed also:
Freshair hole above throttle pedal half welded in place:
I'l just leave this here
#69
Posted 10 May 2013 - 08:58 PM
Look's good, I'll give you a fiver per wheel ^^^
#70
Posted 10 May 2013 - 09:00 PM
Cheers alex, haha deal on a fiver for each centre cap ![]()
#71
Posted 10 May 2013 - 09:04 PM
looking goooood. did the tin foil work better on the rear light? and are you having that light fitted to? cheers tom
#72
Posted 10 May 2013 - 09:09 PM
Cheers tom
It did improve yes (have a look on my previous update), would have been better if i didnt sit on the foil
Probably not as i want to keep the checkmate original (wheels are hard to find
#73
Posted 10 May 2013 - 09:15 PM
might asswell would be nice to see it on other minis to. what wheels are those above i have some like that for sale in wheel section.
#74
Posted 10 May 2013 - 09:21 PM
Yeah might to it on mine but id prefer a steel one to alter how i want its internals.
There 6x10 cosmics
#75
Posted 13 May 2013 - 12:58 PM
You really don't stop do you!
Trying to keep up with all this work that's happened since I've last been on and it's like 10 problems fixed 10 new problems to solve! It's looking good though. ![]()
