1999 Mini 40Se Won't Start
electrical engine
3 replies to this topic
#1 Liam Healy
Liam Healy
    Starting My Mini Up
  • 4 posts
Posted 14 April 2019 - 09:09 AM
Good Morning,
My 1999 Mini 40SE will not start.
I am sure that the battery is not dead, as it is a fairly new battery, and when I discovered it was not starting I checked and confirmed that nothing had been left switched on.
The car is completely dead. None of the lights, radio, internal light etc turn on.
When turning the key absolutely nothing happens, complete silence.
I suspected that the immobiliser fob battery was dead, and the immobiliser was stuck engaged, however I have replaced the fob battery and still nothing happens. The red light on the dash is not on so I believe that means the immobiliser is not engaged anyway.
I believe the problem is with the electrics. I shall check the fuse box next as hadn't thought of that until writing this.
If anyone has any tips it would be appreciated.
Thanks,
Liam
#2 Steve220
Steve220
  • 5,146 posts
  • Local Club: BMC
Posted 14 April 2019 - 10:20 AM
Are you sure or are you 100% sure the battery isn't dead? That would be my first port of call as MPi's are dreadful for parasitic drain, which is why most leave them on trickle chargers.
#3 roblightbody
roblightbody
  • 460 posts
Posted 14 April 2019 - 06:41 PM
How Long was it left for?
#4 bartman
bartman
  • 265 posts
Posted 14 April 2019 - 08:40 PM
If you have no lights at all then the battery is dead, or not connected.
Also tagged with one or more of these keywords: electrical, engine
