You could always p clip the brake an fuel lines to the side of one of those roof beams out of the way.
Genius! Perfect solution, cant believe I didn't think of that.
Posted 05 May 2020 - 12:48 PM
Posted 05 May 2020 - 12:54 PM
Can anyone tell me the best way to strip old paint, stone chip etc off the areas I want to check for rust and then repair / zinc prime? I don't want to damage the metal too much in the process and I feel like a grinder isn't always the best way to go especially for some of the better flat panels. Excuse me if I am being dumb.
Posted 05 May 2020 - 01:23 PM
You can try paint stripper or i prefer a wire cup on a grinder.
Posted 05 May 2020 - 01:46 PM
I went with a wire wheel on an angle grinder, but I went through dozens of them and I don't want to know how much it cost me in the end. It makes a lot of dust so wear a mask and goggles!
Don't go too hard on flat large panels like doors, quarter panels and roof because it can warp them!
Posted 05 May 2020 - 02:01 PM
I would go with a paint stripper on the big flat panels or where you do not suspect rust.
And wire wheel where there is rust, or suspected to be.
I've decided to acid dip the body, but this is pricey and only because it's a keeper. But then there is no surprise in the end. All the rust is easily seen.
Once repaired there will be a second dip to remove surface rust and then an e-coat.
The shell should then be rust-proof ;)
Posted 05 May 2020 - 02:17 PM
Thanks for the advice. Maybe in another 10 years I might do this. For now I just want her back on the road so we can start to enjoy it again. Plus we don't have that sort of money to spend at the moment.
Posted 05 May 2020 - 05:47 PM
My preferred paint stripper is starchem synstrip. Removes paint easily but not sure on stonechip.
As with all chemicals, wear gloves and a mask as it's quite unpleasant stuff.
Twisted wire brush in a grinder is good for undersea but it's a messy job as has been said.
I use https://www.nortonab...aze-rapid-strip In the grinder too as they remove anything without damaging metal but you still have to be careful with heat build up.
Cheap ones are available but last minutes so a bit of a false economy
Posted 05 May 2020 - 06:39 PM
Posted 05 May 2020 - 10:00 PM
Posted 19 May 2020 - 08:28 AM
Posted 19 May 2020 - 08:48 AM
That's a good step forward!
Now you will delect yourself about the benefits of having this jig ;)
That's a small garage, but you still can work on the car and roll it (is it tight with the car on its side?)
Gilles
Posted 19 May 2020 - 08:56 AM
Posted 19 May 2020 - 09:14 AM
Posted 19 May 2020 - 09:37 AM
Excellent work Ben, the fun really begins now! You will soon have a grinder addiction to match Nik from Project Binky....
Posted 19 May 2020 - 11:26 AM
Gilles
Thanks gilles, yes still got plenty of room. Bit tight but it spins all the way around and doesn't hit the roof beams which is what I was worried about. If it had I would have removed the castors but thankfully it is fine.
Projects →
Mini Saloons →
1965 Austin Mini Restoration - Canadian Mk1Started by DoubleEh , 14 Nov 2022 roundnose |
Projects →
Mini Saloons →
Project Joe - 1991 Mini Mayfair 998Started by Eggers , 02 Jun 2022 roundnose |
Projects →
Mini Saloons →
Mpi Dashboad ProblemStarted by mikeprez , 22 Dec 2021 roundnose |
Projects →
Mini Saloons →
1978 Oew - Willy The MiniStarted by smalltreegrower , 11 Nov 2021 roundnose |
Projects →
Mini Saloons →
1968 Mk2 Cooper BuildStarted by Minime998 , 15 Sep 2021 roundnose |
