Getting The Rose Family Mini Back On The Road! (After 5 Years)
roundnose
297 replies to this topic
#76 Ben Rose
Ben Rose
  • 210 posts
Posted 16 July 2019 - 09:31 AM
I wish I'd photographed more of my MPI while stripping it, but luckily I can use your build as a reference now, ha ha.
Your welcome!  :lol:  :highfive:
#77 Ben Rose
Ben Rose
  • 210 posts
Posted 16 July 2019 - 09:34 AM
Just read through the thread, keep up the good work, and don't worry about the speed you're going at, progress is progress!
Thank you!  :-)
#78 Ben Rose
Ben Rose
  • 210 posts
Posted 22 July 2019 - 08:51 AM
Very brief update, I took the passenger side door off and sheared off all four bolts event after spraying them with penetration fluid every day for a week.  Gutted.  Another small task t add to the list.
If anyone has experiance in fixing this common issue and has any tips they can offer I would appreciate it!!
Door off (you can see how bad the N/S wing was).  The arch practically fell off.
Disk is clearly unrecoverable and Callipers don't look far behind. Its amazing what sitting still on a drive for a year and in a garage for 4 years does to a car.
Edited by Ben Rose, 22 July 2019 - 08:53 AM.
#79 rich_959
rich_959
  • Just Joined
  • 568 posts
Posted 22 July 2019 - 09:05 AM
The old tin worm is a powerful thing isn't it! If your arches are in decent condition, hang on to them as it seems originals are getting hard to find. I stupidly gave a set away to a chap who bought some other bits and pieces that I didn't need after stripping my car down.
#80 Ben Rose
Ben Rose
  • 210 posts
Posted 22 July 2019 - 12:31 PM
Mad, genuinely believe they must have cut corners on these later 99-00 cars.  Good tip about the arches.  Mine seem OK so I'll keep hold tight.
#81 Ben Rose
Ben Rose
  • 210 posts
Posted 23 July 2019 - 10:48 AM
On to the interior removal...
Front seat brackets look a bit rusty but saveable.
Carpet looks good so I am going to try to recondition it. Just these little protection plates need to be removed and replaced. Not sure how to do that yet.
Little self tappers holding rear seat in.
Rear door bins are dirty but saveable.
Reminding myself the order the seatbelt goes back in.
Stone chip inside rear door bin??
And on panel under rear seat. panels look in relatively good condition.
Enough for tonight.
#82 Ben Rose
Ben Rose
  • 210 posts
Posted 23 July 2019 - 10:53 AM
Found the original manuals too which I'm really pleased about.
#83 johnR
johnR
  • 2,322 posts
Posted 23 July 2019 - 05:08 PM
You might as well get new discs but the callipers usually clean up OK - easiest way is to have them blasted (crimp the pipes and leave the unions in place so media doesn't get inside them)and either zinc plate or paint them.
#84 Ben Rose
Ben Rose
  • 210 posts
Posted 23 July 2019 - 05:43 PM
Cheers John. I'll try cleaning them up and post results on here.
#85 Ben Rose
Ben Rose
  • 210 posts
Posted 29 July 2019 - 09:22 AM
So managed to get a bit more done over the weekend...I am still pushing to get the wiring loom out and then engine.
Remaining seat belts out, rest of rear seat and rear door cards. The positive is the rear of the car seems in good condition.
Starting to pull the dash apart. Scared of what I will find as the rust falling on to the floor is incredible.
Plenty of sound deadening I can reuse as it looks to be in good condition considering what it is hiding.
First bolt removed on passenger side holding dash in
Don't know what this small illumination box "post 97 is". Must have changed the dash lighting for MPI.
Second bolt removed in centre of dash through radio hole.
Third and last bolt on drivers side is much more hidden.
I was fiddling with the dash when I managed to just pull off the entire top dash pad!!!!!!!! what the hell. It just fell apart in my hands.
Dash is out...
Back of Dash, it appears the rev counter is a separate module to the speed and temp gauges..
Laminate is coming away from the dash, repairable?
Behind the dash looks bad, I'm guessing there should be some kind of top rail which came away with the dash pad.
Boxing all the dash up..
Back out there tonight..
#86 cooperd70
cooperd70
  • 793 posts
Posted 29 July 2019 - 10:26 AM
Great detail you have there in the photos your posting...keep up the good work. shame it wasn't a project started so that it was finished in time for the IMM! You'll have to get it to a show once it's restored as we'll all want to take a butchers ?
#87 Ben Rose
Ben Rose
  • 210 posts
Posted 29 July 2019 - 11:20 AM
Ahh cheers, yeah may be next year! :lol: When its finished I'll definitely be going to some shows.
Edited by Ben Rose, 29 July 2019 - 07:13 PM.
#88 bdean
bdean
  • Just Joined
  • 102 posts
Posted 01 August 2019 - 01:34 PM
Agreed  :shy: I haven't taken nearly enough photo's when stripping my MPi so this thread will really come in handy. I sent my wiring loom away to be fully tested and repaired and should hopefully get it back soon (with a few upgrades). Not looking forward to trying to put it back in  :X
#89 Ben Rose
Ben Rose
  • 210 posts
Posted 02 August 2019 - 07:10 AM
Good luck! I'm completely new to restoring a car so the number of photos was really to document my progress and to help me out putting it all back together. If its helping others too then it makes it even more worth it.
I've just got the original carpet up and the floor looks great. I'm just trying to figure out how best to remove the heater unit and wiring behind the dash.
So far it seems my major issues will be the front end.
#90 rich_959
rich_959
  • Just Joined
  • 568 posts
Posted 02 August 2019 - 09:54 AM
Yours is similar to my MPI Ben, with the difference being that someone had done a lot of the front end repairs previously (albeit to a poor standard). Everything from the front bulkhead backwards on mine is remarkably solid, but I can only assume that water ingress from the screen did most of the damage at the front. It had had a dodgy scuttle replacement and new front end, but I think it was Stevie Wonder who did the panel fitting. It's all had to come off again, including inner wings etc.
Back when I had a brand new MPI in 1998, I remember parking mine up wet in my parents garage (I know, I know, I was young and stupid) and was horrifed just a month later with the surface rust I found in the engine bay. You can see what dry ventilated storage does for a mini by looking at the MPI that Ben at Mill Road Garage is currently working on. Just goes to show, even these late cars can survive!!
