So, another update
Obviously, haven't had alot of time to work on the mini due to the snow, but have still made some progress.
First job, was to get both the upper and lower dash rails in.
After that, the switch panel was bolted in, and the switches added. Originally it would've only had 4 switches, and the other switch placed in a small plastic panel under the lower dash rail on the passenger side. I didn't like that, so we got a 5 hole switch panel from a later mini
Went rumaging through the garage and my bottom draw for the switches, and found that they were all very faded, and looked appauling. In the past I had read somewhere that by rubbing Peanut Oil on the switches, it brings them back to life.
Armed with some of this:
I rubbed all the switches with it, and they came up really well i think:
(They still hadn't completely dried when I took this picture)
That was two weeks ago, but since the snow ruined our lives, only had chance to start on the mini ever so often.
Eventually there was a day where we could get some more work done. We had bought a new headlining set from Retro Retrims not too long ago. So we decided to make a start on fitting that
First of all we had to put the old rails in to the new headlining, and this went well. We were putting the rails in the mini, and the front one snapped
So we had to wait a couple of days until we could go down to Somerford Mini to pick up a new one.
Whilst waiting to have the chance to use the new rail, we left the headlining in place - short of one rail. This became tedious, so I thought it would be a good idea to fit the rear numberplate
I got them for christmas (front and rear) and they are the pressed alluminium type
Then after that success, we went and picked up that headlining rail. Not the most exciting purchase ever made, but it was essential.
After slotting that rail in place, we had to get started on sticking the headlining in.
We used dozens of clips to pinch the headlining to the shell:
After clipping in the front and rear of headlining, it looked like this:
Not bad at all for a first time thing, once its stretched to the sides it will be flatter
My apologies, as I don't have a picture of the headlining as it is now, its fully stuck in. But I do have pictures of the car with some seals on now, which somehow makes the side of the car look alot neater I think
Ah just found this picture, sort of shows the headlining. Yeah the corners are a bit creased, but I'm alright with that
After the door seals and rear quarterlight seals were in, it was time to clip on the gutter trim, thrilling
Not a very good picture, but it gives the roof a more defined edge, making it alot nicer
And that is all for now
Edited by 88minicity, 16 January 2010 - 09:03 PM.
