9973 replies to this topic
#4246 Motorblock
Motorblock
    Just On Tickover
  • 6 posts
Posted 12 August 2014 - 01:26 PM
Removed fuel tank, both radius arms and rear sub frame!
#4247 silve1999
silve1999
  • 1,146 posts
  • Local Club: MiniFreakz, Brighton Mini Club
Posted 12 August 2014 - 01:28 PM
hit about in the engine bay with a hammer
#4248 59 Speed
59 Speed
    Formally know as Smackfiend
  • 674 posts
Posted 13 August 2014 - 10:54 AM
Did the messiest job I've ever done on a Mini - applying underbody wax.
Cavity wax was a bit messy but the the underbody was a complete mess, went on too thick, dripping all over the place and went everywhere, may never be able to spray another thing in the garage again :-|
I just hope it doesn't look too much of a mess when it's dried
#4249 scrumpix
scrumpix
  • 453 posts
  • Local Club: Yeovil Mini Mania
Posted 13 August 2014 - 12:10 PM
fitted fire extinguisher
#4250 silve1999
silve1999
  • 1,146 posts
Posted 13 August 2014 - 12:17 PM
changed voltage regulator on my old alternator, then took alternator out and replaced with another used one which looks like the rectifier is fried so will be taking it out again soon.
#4251 megamini_jb
megamini_jb
  • 5,491 posts
  • Name: Jamie
Posted 13 August 2014 - 01:30 PM
Stripped it and started cutting front end off ^_^
Edited by megamini_jb, 13 August 2014 - 01:36 PM.
#4252 IainStallard
IainStallard
    I am the first status holder 2014.
  • 1,114 posts
  • Local Club: Box Hill Mini Club, CCMOC
Posted 13 August 2014 - 05:40 PM
Changed back to the standard rocker cover after painting it and the weather shield brackets
#4253 BronkoMini
BronkoMini
  • 1,485 posts
  • Local Club: Mini Fixers
Posted 13 August 2014 - 06:25 PM
Went for the first drive since fitting the new engine, the straight cut drops arnt quite as loud as my mates.
#4254 59 Speed
59 Speed
  • 674 posts
Posted 16 August 2014 - 08:02 PM
Timed up my cam from the top of the valve, set the Kent 286 to 104.5 / 105 degrees ATDC (checked it a couple of times), it should be set to 106 degrees but I've taken into account a little chain stretch.
Setting TDC of number 1 cylinder:
Attached File  image.jpg   78.5K   6 downloads
Setting full lift at number 1 inlet:
Attached File  image.jpg   55.25K   1 downloads
Wasn't as tricky as I thought.
Also fitted my adjustarides and new gaz dampers.
#4255 nocerb
nocerb
  • 15 posts
  • Local Club: Brecon Motor Club
Posted 16 August 2014 - 08:14 PM
Fitted the lamp pod and it all worked.
Now the wife has pinched it to take her sister home!!
Edited by nocerb, 16 August 2014 - 08:15 PM.
#4256 evilpen14
evilpen14
  • 115 posts
  • Local Club: CCC and RAF Mini Club
Posted 16 August 2014 - 08:30 PM
just checking him over for his weekly use. Can't be arsed to collect the daily driver.
#4257 domdee
domdee
    Formally known as dominicdee
  • 1,183 posts
Posted 17 August 2014 - 10:42 AM
would love to have the balls to fit one of these to my baby!
#4258 egoist
egoist
  • 43 posts
Posted 17 August 2014 - 11:46 AM
Is this battery will be good for Mini?http://pages.ebay.co...6855483&alt=web
#4259 egoist
egoist
  • 43 posts
Posted 17 August 2014 - 12:03 PM
Took out a radiator, cleaned cooling system, changed thermostat and fitted new rocker cover gasket. Now time to find a new battery.
#4260 Tommyboy12
Tommyboy12
  • 2,256 posts
Posted 17 August 2014 - 12:08 PM
Found 3 layers of floor pan in the drivers footwell...
