9973 replies to this topic
#5251 Zach P-D
Zach P-D
  • 444 posts
Posted 13 October 2015 - 08:59 PM
looked at some speakers
looked at space under rear seats (already have two on a board but want a discrete sub)
looked at the speakers again
and again, looked at the space under the seats
repeat ^ a few times
set off to my local town to get some MDF to make a sub box
got sidetracked, got a chippy and came home without any MDF.
#5252 fenghuang
fenghuang
  • 796 posts
Posted 15 October 2015 - 01:21 PM
Watched it (the Mini) as it moved sideways and then dropped ... as a scisor jack started to bend underneath it.
Thankfully I was only in the process of putting it on axle stands and had plenty of time to get out of the way, but it was an interesting experience :ohno:
Edited by fenghuang, 15 October 2015 - 01:22 PM.
#5253 briancaveman2003
briancaveman2003
  • 197 posts
Posted 15 October 2015 - 02:06 PM
just gave it a wash & polish and ordered another set off spotlights 8-1/2inch with built in side light. no more buying till after xmas well that's what the wife said take a look follow the link http://s1076.photobu...html?sort=3&o=0
#5254 fenghuang
fenghuang
  • 796 posts
Posted 16 October 2015 - 07:00 PM
Took the head off.
Whilst it's not much more than undoing bolts, considering how many bokts there are to undo on other things first, it's one of the most involved jobs I've done so far. So I'm feeling rather pleased with myself.
Next job? Cleaning. Cleaning. More cleaning. And then valve stem oil seals!
#5255 joshw
joshw
  • 154 posts
Posted 16 October 2015 - 07:21 PM
Dropped the rear subframe off to the body shop now to start on the front
#5256 Rocket.
Rocket.
  • 1,444 posts
Posted 16 October 2015 - 07:27 PM
Collected it from the body shop after having a new windows and headlining fitted
Looks like a proper car again :proud:  :D
#5257 Big Sam
Big Sam
  • 853 posts
Posted 17 October 2015 - 05:07 PM
Starting taking the clutch slave cylinder and gave up because i just get can't to one of the bolts. Water bottle removed and one slightly buggered engine stabiliser removed, bracket on the bulkhead will nee replacing as it sorta disintegrated in the removal process!
Oh and made a dolly out of a pallet and some wheels to stick the mini on when stripped.
Edited by Big Sam, 17 October 2015 - 05:25 PM.
#5258 Rocket.
Rocket.
  • 1,444 posts
Posted 17 October 2015 - 05:26 PM
Torqued up the flywheel bolt after finding a socket big enough
Then started preparing the engine bay for getting the engine fitted
#5259 Itsjustanestate
Itsjustanestate
  • 43 posts
Posted 17 October 2015 - 05:38 PM
TIG Welded up the trim pop rivet holes down the side on my estate. Then started cleaning up the front inner wing and widescreen corner ready for a small rep are plate.
#5260 sh4ne
sh4ne
  • 17 posts
Posted 17 October 2015 - 06:10 PM
Cutting out more rust :(
Need new inner and outer sill and might as well fit a new front floor too!
Need to read up on how to do this first...
#5261 fenghuang
fenghuang
  • 796 posts
Posted 17 October 2015 - 06:52 PM
Scrubbed the head. Inside and out. It's still covered in crud. :-(
#5262 Mini-Hazel-Nut
Mini-Hazel-Nut
  • 607 posts
  • Local Club: Birmingham Mini Owners
Posted 18 October 2015 - 03:21 PM
Put me new dizzy drive and dizzy in today, then found that the clamp bolt wouldn`t reach the hole because I got a Smiffys clamp. Finished off the stainless LCB and found that the 2 into 1 part fouls the floor, *******!  :xxx:
#5263 cp2708
cp2708
  • Just Joined
  • 171 posts
  • Local Club: LSMOC
Posted 18 October 2015 - 03:59 PM
Replaced gearbox steady with poly version. Still clonks when taking up drive. Also replaced the 13 month old perished rubber lower arm bushes for poly ones. Much better!
Edited by cp2708, 18 October 2015 - 03:59 PM.
#5264 59 Speed
59 Speed
    Formally know as Smackfiend
  • 674 posts
Posted 18 October 2015 - 04:38 PM
Have you tried it both ways? Mine was close on the way it was meant to fit but the other way is impossible.
If it's the specialist components one the lambda sensor hole should point towards the passenger / near side.
Edited by Smackfiend, 18 October 2015 - 04:39 PM.
#5265 Itsjustanestate
Itsjustanestate
  • 43 posts
Posted 18 October 2015 - 05:18 PM
Fitted O/S full floor to my clubman estate. All ready to weld up.
