9973 replies to this topic
#5266 Big Sam
Big Sam
  • 853 posts
Posted 18 October 2015 - 06:00 PM
Got engine stabilisers off along with removed heater air intake. Still can't get the clutch slave off!
#5267 Mini-Hazel-Nut
Mini-Hazel-Nut
  • 607 posts
  • Local Club: Birmingham Mini Owners
Posted 19 October 2015 - 04:14 AM
found that the 2 into 1 part fouls the floor, *******!  :xxx:
Have you tried it both ways? Mine was close on the way it was meant to fit but the other way is impossible.
If it's the specialist components one the lambda sensor hole should point towards the passenger / near side.
It is that very one and strangely enough as the original mild steel one is still hanging there on the central pipe I copied the orientation of that which put the sensor hole on the passenger side.  It`s touching the nearside of the tunnel quite low down. Not massively but I suspect enough to transmit resonance to inside.
#5268 Big Sam
Big Sam
  • 853 posts
Posted 19 October 2015 - 06:42 PM
Got the clutch slave cylinder off!
#5269 ryan22_lgm
ryan22_lgm
  • 1,478 posts
Posted 19 October 2015 - 06:46 PM
a fair bit of welding :D
#5270 fenghuang
fenghuang
  • 796 posts
Posted 19 October 2015 - 06:50 PM
Got the head nice an clean.
Then found neither my valve spring compressor nor my biceps are quite up to the job.
#5271 spiguy
spiguy
  • 1,537 posts
Posted 20 October 2015 - 12:53 PM
yay!  I have been watching your content with amusement (sorry, I hope you don't mind :lol: ) at how much the slave cylinder was pi55ing you off. Just amusing because I can understand your frustration. Loved it when the quick comment came up "Damn and blast at slave cylinder removal"
Edited by spiguy, 20 October 2015 - 12:54 PM.
#5272 fenghuang
fenghuang
  • 796 posts
Posted 20 October 2015 - 04:15 PM
Today I gave up on the Sykes Pikavant valve spring compressor and took it back for a refund.
Then I carefully measured a Clarke valve spring compressor form Machine Mart.
When I got it home and tried to use it, it turned out I'd mis-measured, or the thing had deformed on first contact or something.
So I took that back for a refund.
Then I tried a different Clarke valve spring compressor form Machine Mart. One that couldn't possibly be too big for a fecking A+.
AT LAST.
Then I ran out of time.
But at least I got one valve lapped.
It's only take 2 days so far. SHould have them all done by Xmas.
#5273 crackfoo
crackfoo
  • 304 posts
Posted 20 October 2015 - 04:58 PM
Took Rupert in to FORD for an alignment! Was one of the only places in the city with the new style alignment machines that would fit on 10" wheels.
#5274 Rocket.
Rocket.
  • 1,444 posts
Posted 20 October 2015 - 05:47 PM
Fitted new shocks
Then put the fuel tank back in
#5275 Cookiez
Cookiez
  • 205 posts
Posted 21 October 2015 - 03:02 PM
Seam sealing
#5276 lawrence
lawrence
  • 1,341 posts
Posted 21 October 2015 - 09:13 PM
Went to start her. Aux belt squealed. It's 6am. Swore at it. Gave it a Rev. Pulleys didn't bite.Turned it off
Sat for a bit.
Needed to be at uni for 7am. Had 55mins for a 50mins journey.
Do I use motorbike?, nope it's cold and wet and I'll be sulky all day.
Wake up dad. "Can I borrow skoda mini is being annoying"
Borrow scoda, sneakysneak to uni (God it's quiet driving a brand new car)
Get home
Look at the aux belt on mini
Loose again.
Ahhhh little curse word!
Tommorow to be tightened
Really should fit a tensioner to the system but there's no room!!! :(
#5277 fenghuang
fenghuang
  • 796 posts
Posted 21 October 2015 - 09:16 PM
Big girls blouse! ;-)
#5278 lawrence
lawrence
  • 1,341 posts
Posted 21 October 2015 - 10:09 PM
Come on would you? Did a risk assesment of the situation
Cold!
Dark!!
Raining!!!
125 on skinny tyres
40miles commute
Oh and no waterproof trousers (torn)
Vs
Warm
Comfortable
Thermos of tea!
Radio 1
Super sneaky Eco Skoda
I didn't want to become a statistic and test the durability of my protective gear haha.
(I know your joking by the way)
#5279 fenghuang
fenghuang
  • 796 posts
Posted 21 October 2015 - 10:30 PM
If it's Radio 1 vs a 125 with skinny tired, cold wet roads and no waterproofs, I'll take my chances with Death.
If Radio 4 or 6 Music were in offer, I might go for the Skoda.
#OldFaet
#5280 Rocket.
Rocket.
  • 1,444 posts
Posted 22 October 2015 - 04:55 PM
Collected more freshly blasted parts
