9971 replies to this topic
#5551 kevinstowmarket
kevinstowmarket
  • 25 posts
Posted 19 February 2016 - 06:37 PM
Back from the body shop to develop an electrical fault.... sigh
#5552 robocx
robocx
  • 34 posts
Posted 20 February 2016 - 10:16 AM
I now have a 2 speed heater,bought a repair kit for the resistor and soldered it in,£5 sorted,works fine,but then broke the brake pedal switch trying to get the heater box pipes back on,so had to go and buy one of those as well!!! Always something to fix
#5553 bangermadness08
bangermadness08
  • 283 posts
Posted 20 February 2016 - 04:37 PM
If anyone would be willing to help me take out my engine then I could wright what I've done lol
#5554 jsor26
jsor26
  • 64 posts
Posted 21 February 2016 - 12:36 AM
started tear down to install new atb diff and o2 sensor for afr gauge and decided might as well ditch mech. fuel pump and install elec one, spring is looking like its coming early so i want to be ready
#5555 mina08
mina08
  • 255 posts
Posted 21 February 2016 - 06:15 AM
New fuel trap fitted slight hesitation has gone. Need better vac lines.
#5556 oknights
oknights
    Just On Tickover
  • 6 posts
Posted 21 February 2016 - 03:38 PM
Rear suspension cones changed, fronts removed - waiting on top arm rebuild kits. Hi-lo's cleaned up, rocker gasket replaced, thermostat gasket replaced...
Not much left to do until its back on the road for spring! its been a long winter!
#5557 1970razz
1970razz
  • 22 posts
Posted 21 February 2016 - 03:48 PM
Went for a blast around Norfolk , my daughter drove n I held on , just popped a wheel off for a bit more stone chipping work
#5558 slowy
slowy
  • 71 posts
Posted 21 February 2016 - 05:49 PM
Another order sent to mini spares final parts for engine rebuild.
#5559 James_eaton_thewholething
  • 1,063 posts
Posted 21 February 2016 - 06:27 PM
Started getting the body ready for painting just got some bits of filler to finish over the next couple of days then will finish painting inside the boot ready for a whole tube of seam sealer to be used on the car
#5560 Rob B
Rob B
  • 12 posts
Posted 21 February 2016 - 07:02 PM
Struggling with the wiring.
Got facet fuel pump, and can hear it through the stereo's speakers.
Any ideas out there?
#5561 David128
David128
  • 644 posts
Posted 21 February 2016 - 08:14 PM
Fit a non electrolytic capacitor and resistor across pos and ground. to suppress motor
#5562 need4speed
need4speed
  • 83 posts
Posted 23 February 2016 - 09:44 AM
 I've got the front subframe back in the car but it's proving awkward to line up because something's not quite straight! It came out of the car but with new mounts it doesn't want to line up. All suggestions are welcome. :mmkay:
Additionally the wiper motor wiring is done, new diff seals are in and track-rod ends are fitted.
#5563 Rob B
Rob B
  • 12 posts
Posted 23 February 2016 - 07:54 PM
Hi David128
Thanks for that.
Any ideas on rating for the capacitor and resistor?
Rob
#5564 David128
David128
  • 644 posts
Posted 24 February 2016 - 06:17 AM
HI Rob
please follow link  easier than typing it out   https://www.pololu.com/docs/0J15/9
#5565 Rob B
Rob B
  • 12 posts
Posted 24 February 2016 - 12:29 PM
Hi David.
Many thanks, I'll give it a try.
Rob
