#5611
Posted 16 March 2016 - 07:43 PM
#5612
Posted 16 March 2016 - 09:00 PM
#5613
Posted 17 March 2016 - 07:12 PM
Polish the over spray of my wheels and wax them up. They are gleaming!
Posted 17 March 2016 - 07:26 PM
fitted new 50 mm wheel studs & 10 mm shims wheels now fill arches
Don't air tools make life easy?? used die grinder to contour inlet manifold to spacer,, happy days
Edited by David128, 17 March 2016 - 07:27 PM.
#5615
Posted 17 March 2016 - 11:02 PM
Over the last few days, fitted a new downpipe to my SPi (took 5 hours thanks to studs snapping and having a lack of clearance etc etc...) and also fitted as new manifold gasket, new air filter and screws. Much quieter and smoother now as the exhaust is doing it's job! Tomorrow morning I plan to clean up all earthing points and add another engine earth strap :)
#5616
Posted 18 March 2016 - 12:21 AM
Servo nuts are a good place to attach an additional earth strap. Nice and easy access.
#5617
Posted 18 March 2016 - 08:10 AM
Edited by cp2708, 18 March 2016 - 08:11 AM.
#5618
Posted 18 March 2016 - 01:13 PM
I put the new one on the top starter motor screw, which screws into the transfer casing. Then, I drilled a hole through the ECU bracket and mounted it through there (haven't affected the ECU earthing at all).
Seems to have worked..
#5619
Posted 18 March 2016 - 06:33 PM
I got the electric side windows for my estate finished.
#5620
Posted 19 March 2016 - 04:36 PM
5 minute job since i didn't fit the shear bolts the last time.
#5621
Posted 19 March 2016 - 05:01 PM
Posted 19 March 2016 - 06:09 PM
Fitted a new clutch master cylinder.
Another original part bites the dust and yes I lost the pin which secures the pedal to the cylinder. What do you expect when you're almost stood on your head under the dash trying to hold a torch in your mouth......
#5623
Posted 19 March 2016 - 09:50 PM
... Well not today, but the last things which I had done my mini was a dent from the roof and a small section of surface rust on the rear side window panel removed, upon having the whole top roof and rear side panel resprayed.
Had it all done last weekend.
#5624
Posted 21 March 2016 - 07:31 PM
Applied rust converter to my fan cowling. I will get it sprayed up in the next couple of days so that it looks a bit better when I put my new rad in.
7 user(s) are reading this topic
0 members, 6 guests, 0 anonymous users
Bing (1)
