9970 replies to this topic
#9841 RichMPiBlue
RichMPiBlue
  • 556 posts
Posted 20 November 2025 - 01:51 PM
Some small paint work touch up on the inner drivers door.
#9842 IronmanG
IronmanG
  • 1,362 posts
  • Local Club: Box hill. Lsmoc member
Posted 22 November 2025 - 12:21 PM
Removed ecu loom and dash ready for a few winter quality of life improvements.
#9843 lsto
lsto
  • 718 posts
Posted 22 November 2025 - 08:12 PM
Refitted my exhaust after removing it by driving over a hose in the street. Also treated it to some new bits in the minispares sale.
#9844 RichMPiBlue
RichMPiBlue
  • 556 posts
Posted 26 November 2025 - 12:47 PM
Put some Liqui Moly fuel injector cleaner in the tank + some more bits and bobs.
#9845 Sean C
Sean C
  • 198 posts
Posted 26 November 2025 - 05:23 PM
Spent the day looking out parts for my Mk3 (namely rear radius arms) and found what I thought was a pair that I reconditioned a few years ago only to discover that they are both left hand arms. Eventually found the right hand arms so I'll need to order a pair of pin kits and get these 2 reconditioned
#9846 TRS666
TRS666
  • 32 posts
Posted 26 November 2025 - 06:18 PM
Attached File  Motor.jpeg   240.26K   2 downloads
Engine running. 20 minutes at 2500RPM to run in new cam. Retorque head and adjust valves. But clutch is not releasing? Something for tomorrow.
#9847 RichMPiBlue
RichMPiBlue
  • 556 posts
Posted 28 November 2025 - 12:16 PM
Applied Dinitrol black underboby rust proofing. Sticky stuff!
#9848 TRS666
TRS666
  • 32 posts
Posted 29 November 2025 - 05:49 PM
50 meters testrun, not insured yet. Clutch OK now but needs some tinkering with ignition and the Dellorto.
#9849 IronmanG
IronmanG
  • 1,362 posts
Posted 29 November 2025 - 07:31 PM
Turbo and intercooler fitted. Just the loom to go, ready for the dyno next week....
#9850 sonscar
sonscar
  • 3,242 posts
Posted 05 December 2025 - 10:27 PM
Had a hundred mile drive up the M1 this evening,challenging with heavy rain,surface water and winds.Water kept getting on the fanbelt causing it to slip,tense moments.Steve..
#9851 RichMPiBlue
RichMPiBlue
  • 556 posts
Posted 08 December 2025 - 01:33 PM
Finally got round to fitting the stainless steel coolant hose kit from Smiffys mini parts.
Whats-App-Image-2025-12-08-at-13-22-53.j
#9852 IronmanG
IronmanG
  • 1,362 posts
Posted 08 December 2025 - 06:55 PM
Engine at the dyno....
#9853 RichMPiBlue
RichMPiBlue
  • 556 posts
Posted 11 December 2025 - 05:44 PM
Added some silicone adhestive sealant to front windscreen.
#9854 Mito
Mito
  • 458 posts
Posted 13 December 2025 - 04:31 PM
Replaced the brake fluid and coolant
#9855 Shooter63
Shooter63
  • 1,278 posts
Posted 14 December 2025 - 03:19 PM
Chugging along with the winter upgrades RHD pedal box in, fug stirrer heater out, and trail fitted a tart piece, I've always liked the MGB choke lever, a bit of filing and Robert is one of the family.
Shooter
