Street Sleeper 998
235 replies to this topic
#166 Stevee
Stevee
  • 0 posts
  • Local Club: #
Posted 06 March 2011 - 12:40 PM
Hey people :P
went to see martin at MRA Mini's
He said my Ponies in the stable should be about 70ish with everything i want :thumbsup: I WAS Over the moon with that
so need to save up for everything now im budgeting £350 - £400 :) i told him id rebuild the engine
just cause its my engine and i want to :P
#167 1984mini25
1984mini25
  • 8,850 posts
Posted 06 March 2011 - 12:58 PM
Hey people :P
What engine spec is that for then?
Just wondering, as I still need to get a suitable needle to get mine running properly.
#168 Stevee
Stevee
  • 0 posts
  • Local Club: #
Posted 06 March 2011 - 01:03 PM
Hey people :thumbsup:
He said my Ponies in the stable should be about 70ish with everything i want :) I WAS Over the moon with that
998 + 40
sw5 cam
lightend fly wheel
lighted clutch back plate
12g940 head
Pocketed block
flat top pistons (i think) if not dished
Hs4 carb to start with or HIF 38
then might bump up to twins :P
gear box is just a standard 998 with 3.444 final drive :) and center oil pick up
#169 twrminisport
twrminisport
    Jesus
  • 913 posts
Posted 06 March 2011 - 03:37 PM
998 + 40
sw5 cam
lightend fly wheel
12g940 head
Pocketed block
gear box is just a standard 998 with 3.444 final drive :thumbsup: and center oil pick up
And your doing all that for £350-£400? Id triple it mate!
What year is your car. Because if you have a verto clutch you will need to change the clutch to pre-verto in order to lighten it properly as you cant make any worthwhile gain on a verto type.
A fullly lightened flywheel and clutch assembly for a pre-verto is £680 from Swifty from memory and the sw5-07 duplex kit is about £220. You need the duplex kit else theres no point fitting the cam if your not going to time it properly. And 1.3 roller rockers are about £200 so thats over a grand without headwork, final drive, gearbox and replacing the clutch -.-
70 ponies sounds good for that spec :) Wonder what ill get with twin HS2's and a trackday cam :P
Edited by twrminisport, 06 March 2011 - 03:38 PM.
#170 Stevee
Stevee
  • 0 posts
  • Local Club: #
Posted 06 March 2011 - 04:31 PM
998 + 40
sw5 cam
lightend fly wheel
12g940 head
Pocketed block
Nah dont need to :)
i got pre verto fly wheel
my engines a 1976 engine
and 1.3.1 ratio rockers i got a set sat in my shed ^^
and oh i got my duples kit :) ill metro cam it then
#171 miniman92
miniman92
  • 761 posts
  • Local Club: Crewes Missiles
Posted 06 March 2011 - 06:43 PM
I dont mean to put a downer on things mate but I doubt 70bhp is achievable with an sw5, more like 60bhp. Your more likely to get a torquey motor with that spec, which to be honest is what you want.
#172 Stevee
Stevee
  • 0 posts
  • Local Club: #
Posted 06 March 2011 - 06:44 PM
just going by what Martin at Mra Mini's said
and only a town cruiser anyways
#173 twrminisport
twrminisport
    Jesus
  • 913 posts
Posted 06 March 2011 - 08:10 PM
Yeah you might get 70 if you are starting with a good engine but you will be lucky. A 276 would give you this power.
Even with the pre-verto youve got double your budget for a full lightened clutch and flywheel assemby £680
http://www.swiftune....e-assembly.aspx
#174 Stevee
Stevee
  • 0 posts
  • Local Club: #
Posted 06 March 2011 - 09:38 PM
You are going buy swift tune :D i am not you see
yes there an Ok company in my eyes
But Im Using MRA Mini's cause martin is a good old chap, knows what he's on about and local
so its all good :P
#175 DaveVader
DaveVader
  • 942 posts
Posted 06 March 2011 - 09:44 PM
It's all about the local. Martin is doing my Turbo build.
Rebore, drilled for 11 studs, prepped for dry decking plus the rest of my head work, crank work and con rod work.
He'll be doing my gear box and diff too. Well, hopefully, I will just have to give him loads of money!
#176 Stevee
Stevee
  • 0 posts
  • Local Club: #
Posted 06 March 2011 - 09:49 PM
Yeah sounds good :P
Rick.spi also doing his turbo project via martin aswell :D
my block just getting + 40 & pockects ;D
#177 twrminisport
twrminisport
    Jesus
  • 913 posts
Posted 06 March 2011 - 10:16 PM
Ahh fair enough its all about who you know and trust :D
Known swifty for a while now and the results speak for themselves.
:P
#178 Stevee
Stevee
  • 0 posts
  • Local Club: #
Posted 06 March 2011 - 10:37 PM
Ahh fair enough its all about who you know and trust :P
;D
Fair Enough :-
See MRA is 5 min drive from where i live and i got martins number so i can ring order stuff then go pick it up :) so tis all good
hes got most things in stock and makes some good stuff :D
#179 DaveVader
DaveVader
  • 942 posts
Posted 06 March 2011 - 11:56 PM
Yeah sounds good :P
Indeed he is, he's got some good stuff down at Martin's place at the moment.
I'm going to have to give Rick a run down the strip once we're both built!
#180 Stevee
Stevee
  • 0 posts
  • Local Club: #
Posted 07 March 2011 - 12:19 AM
Yeah sounds good ;D
my block just getting + 40 & pockects :-
DO it :P id come see that and join in ;]
sure if i take doors, boot lid, bonnet, seats and get in naked i could just keep up with both of you
