Tahiti blue, fast road build.
#316
Posted 03 October 2007 - 06:57 PM
#317
Posted 03 October 2007 - 07:25 PM
#318
Posted 04 October 2007 - 08:04 PM
I do like your mini.
Is it alright if i use some of those pics for wallpapers on my pc and phone?
Very nice pics loving everything!
Cheers James.
#319
Posted 05 October 2007 - 08:53 PM
few things happened. last night she started to missfire, so i was tootling home when the rollpin in the gear linkage poped out! so the i was sat in a road doing 20mph in fourth unable to change gear, with 3 sets of traffic lights ahead! luck must have been on my side as i made it home without stoping! got to work early this morning, used a bolt to secure the gear linkage, and tracked the missfire to a faulty sparkplug.
took it out for a dam good run today, and everything was fine and dandy! maythis be a lesson to you all, don't use old rollpins!!!!
#320
Posted 06 October 2007 - 10:51 PM
cheers man
#321
Posted 07 October 2007 - 06:09 AM
#322
Posted 07 October 2007 - 11:20 AM
Any chance of some pics of the finished interior and a couple of the bit behind the front seats? Looks great!
#323
Posted 07 October 2007 - 02:28 PM
should be an interior picture or two a few pages back, but i'll take some more next weekend for you.
#324
Posted 10 October 2007 - 10:29 PM
new gasket is already ordered, hopefully i can sort it out! will get pictures up this weekend when i get round to fixing it......
Edited by steveobennet, 10 October 2007 - 10:31 PM.
#325
Posted 11 October 2007 - 11:37 AM
#326
Posted 13 October 2007 - 08:53 PM
right, it turns out that my engine steady bush that bolts to the engine melted! don't know if was down to inferior materials, or whether the engine just got too hot. that has been replaced with a new polyurethane bush. i wasn't running a thermostat for about 3 days when it first initally got on the road. what happened with the cooling system was when stationary the engine reached a certian temp, but as soon as you started driving it went straight to the blue on the gauge. so it was overcooling the engine effectively. so i put the 82degree thermostat from the 998, and drilled 2 4mm holes in it, as my bypass for the water pump has been blocked off. so this has made warming up the car alot faster, and keeps it at a stable temperature.
turns out my headgasket went on cylinder 2 into one of the coolant passages. the damage may have been caused by pinking (pre-igntion or detonation) and was finally blown threw due to the boost. it turns out that my actuator (doobrie that controls the boost) had split the hose which causes the boost to push against the diaphram to open the wastegate. this means i was running way more boost than i should (don't know exactly how much, i don't tend to stare at the boost gauge). this is the most probable cause of the pinking and the reason why my headgasket went. a new re-inforced pipe has been used to supply the air to the actuator. a new headgasket, and manifold gasket has been used also. she fired up first time, bit of a misfire but that soon went when it was warm. took her out earlier to get her to temperature, and make sure everything was fine.
my speedo problem of under-reading has hopefully been fixed. i have swapped the pinion from a 17 one to a 15, and accoring to guessworks website (very helpful!) this should give me the correct speedo reading. i check this with a gps soon. i just have to re-torque the cylinder head down tomorrow when its cool, and check the valve clerances and give it a good wash! no pictures unfortunately, was too busy concerntrating on the job in hand.
#327
Posted 13 October 2007 - 09:04 PM
#328
Posted 14 October 2007 - 08:31 PM
Carbon number plates
Maybe a set of those to finish it off
Lovely car.....Tahiti blue is the best
#329
Posted 14 October 2007 - 10:35 PM
how much.. does anybody know?
#330
Posted 15 October 2007 - 04:59 PM
Edited by steveobennet, 15 October 2007 - 05:36 PM.
