Engine Strip Down And Rebuild With Lots Of Confusion :d
#166
Posted 27 January 2012 - 06:06 PM
watched this but still what am i doing to measure the endfloat how do you set the preload??
#167
Posted 27 January 2012 - 06:56 PM
this was with levering the crank all the way over to the timing chain end then levered back the other way i have a reading between 3thou to 4thou probably say 3thou happy days.
took me a while to realise what you meant by levering the crank i thought you meant in turning it over not pushing it up tight (horizontally) whoops.
don't know what you mean by preload.
i do like the new toy measured the bearing journals for the big end caps they are perfect no movement at all good job mr engineer.
#168
Posted 27 January 2012 - 08:18 PM
Funny point I have an engine stand I used it on the dismantle and clean up come to the crank and pistons I thought it was easier on the bench. My dad pops in why you doing that on the bench you have an engine stand mmmm good point second time around I use the engine stand and it's so much easier especially for torquing down the nuts silly me looks like I have some lovely scratched paint work needing touching up oh well
Edited by jameslearwood, 27 January 2012 - 08:20 PM.
#169
Posted 28 January 2012 - 12:19 PM
#170
Posted 28 January 2012 - 01:08 PM
Will get some photos up tonight cheers I am glad I did get one now where do you get the protractor for the timing chain setting is there anything else I need for this?
#171
Posted 28 January 2012 - 05:43 PM
piston ring compressor in action
thrusts on right way round
My favourite new toy for measuring shiny things
Edited by jameslearwood, 28 January 2012 - 05:48 PM.
#172
Posted 28 January 2012 - 06:14 PM
#173
Posted 28 January 2012 - 06:21 PM
#174
Posted 16 February 2012 - 08:15 PM
So I now have a very bruised hand and damaged 5 drifts but the bloody gear selector is free from the shoulder joint b'jesus it took plenty of heat, blood, wd 40, sweat, a few cuses and then repeated. So happy that is off can now put the quick leak fix kit on.
So block is assembled, head valves fitted and everything else prepped just have to weld the timing cover breather back up then it's all assembly time oh happy days
Photos to follow
#175
Posted 16 February 2012 - 11:20 PM
#176
Posted 17 February 2012 - 01:53 PM
Edited by AndyMiniMad., 17 February 2012 - 01:55 PM.
#177
Posted 17 February 2012 - 06:38 PM
Just got into the garage all eager to start rebuild cleaned up and refitted speedo connection then went to fit the minis spares gearbox leak fix kit hmm hit a stumbling block am I right in thinking to get the old seal out I need to take off the diff housing?
If so then god damn it I don't have the gaskets another case of shopping on minis pares and more postage might try uni part first
#178
Posted 17 February 2012 - 07:32 PM
Ermmm... timing cover modified
#179
Posted 17 February 2012 - 07:33 PM
#180
Posted 18 February 2012 - 08:51 AM
