1961 Mk1 Austin Mini 850 - "flying Flea" - Lot's Of Pictures
#136
Posted 24 April 2013 - 11:24 PM
I only have one question though, how well is the engine going to run with a 12g295 head?
I'm only asking because I have no idea and I just bought one for my 998cc
#137
Posted 25 April 2013 - 07:36 PM
looking good.
I believe it the best head you can get for an 850 so i'd say quite well, not sure if i'll be keeping it on there yet though
#138
Posted 25 April 2013 - 08:13 PM
I gave the 4 exhaust valves a quick once over
Next up was to get the engine in a easier place for me to do the dreaded clean, I let dad do the majority of this as it's his area and if I broke something I wont be to blame
Removed the bell housing
I did know the name of this bit but I've forgotten
Flywheel
Fly wheel puller
Fly wheel
Clutch, not seized or anything but there's a chunk broke off that we couldn't seem to find, not sure how that ended up in there
Clutch plate
Engine mount removed
Water pump
Now can't remember what this was, I'm going to say start motor bolt :S
A lot more anti freeze came out with the water pump
Next up was the oil filter
Cracked the nuts then took the distributor off, followed by the filter
Then blocked the holes up
32 year old oil
Not sure what to call this, but we took it off
Took these off, also forgot the name of them but we got some brand new old stock ones of ebay
1 off
2 off
Looking rather... "Mini" eheh
More 32 year old oil
Looking eve more.. "Mini"
Removed some studs
Head studs removed
Then got ready for the dreaded clean, I scraped most of the grease off, tomorrow I'll wash it down
Edited by Thorpsta, 26 April 2013 - 04:55 PM.
#139
Posted 25 April 2013 - 08:54 PM
#140
Posted 25 April 2013 - 10:53 PM
looking great bud. give it a few weeks it will look like new again.
I wish I could skip those few weeks, I hate degreasing and cleaning enough as it is
#141
Posted 27 April 2013 - 10:10 PM
Done a fair bit of cleaning this afternoon, got a dead line of 3 weeks to get the engine cleaned, painted, running and in the motor
I'll let the pictures do the majority of the talking
Pile of parts, went out and got that gear box knuckle thing last night
engine mount
timing eye cover
something to do with the clutch
Fly wheel
Casing, scraped the majority off, I'm doing this tomorrow
Bell housing, I was gonna stop here which is why it's dirty on the inside, but I decided to carry on
Another water pully, I'm going to clean this one as the other one is rusted in awkward places to clean, this one isn't
Clutch bit, it's dirty but I got that with some sand paper
Pile o' parts
Unfortunately we ran out of etch so they get red oxided
#142
Posted 02 May 2013 - 05:47 PM
Done a fair amount on the engine today, casing is all clean but I forgot to take a picture of that.
First I soaked the engine in a few coats of Jizer to get a majority of grease and gunk of it, left it over night then took it into the shed
Can you tell what it is yet?
I noticed this MOWOG stamp was starting to grind of so I thought I'd photograph it before it did
That was as far as I got due to a foot injury I can't stand for long
On another note, the wiring loom has arrived
#143
Posted 03 May 2013 - 10:30 PM
Engine is fully clean, I wont be able to do any work on it till Wednesday when me and dad are going to build it up
The head is almost ready, 3/4 seats are in and the 4th seat is ready to go in... once it arrives, for 10minutes of work its delayed us putting it together for painting by another week
I'll let the pictures talk
#144
Posted 09 May 2013 - 10:19 PM
Well, the camera is playing up again so the majority of these pictures are terrible, sorry
The first job was to remove the remaining studs of the side and give the gears a wash down in petrol
Washed these down in petrol aswell
Cleaned the studs up then did a test fit
I'm really unsure whats up with my camera, if you zoom it in slightly it will sometimes focus, takes about 30 attempts for one decent picture
#145
Posted 10 May 2013 - 08:58 AM
Your camera might need a sensor clean, or it might be in a low light environment and struggling with the auto focus. Is it a DSLR or a point and shoot? If it's a DSLR then switch to manual focus for a bit to see it it's that.
The test fit shot is excellent, which makes me think it is a DSLR camera.
Anyway - enjoying the build - keep updating!
#146
Posted 10 May 2013 - 10:23 AM
I wouldn't know, I'm going to hazard a guess at a point and shoot, the majority of the photos on here I've taken without a flash as it blured quite a bit with a flash on, I've given it a over all clean and I'll see how it goes tonight
Here's a review if it helps
#147
Posted 11 May 2013 - 10:09 PM
Done a fair bit since the last update, my hands are sore from grinding in the valves
Fly wheel is in
Then whipped out the AirFix paint to mark the timing points
Stuck the pressure plate on then the bell housing
Cleaned this clutch cylinder, forgot to take an after picture though
Looking alot better now
That was yesterdays work
Went and picked the head up today, unleaded seats are fitted
Then I started the long...tedious grind.. of grinding the valves in. Managed to get 5 done in a day which isn't too bad
While I was doing that dad put the gear knuckle on and gave the shaft a clean to get the mud and grease out, then refurbed the cylinder you saw above
Not long till paint now!
#148
Posted 11 May 2013 - 10:56 PM
#149
Posted 11 May 2013 - 11:17 PM
Wow....engine is looking new...what all did you use to clean it...may have missed that part
I scrapped some of the bigger clumps of grim off with a scraper and air gun then gave it a good soaking with a engine brush in Jizer, the engine brush brushes dont move and are like a rock, gave it a few scrubbings with that and let it dry up over night as it evaporates and takes grease with it then spent just over a day with a wire brush on a drill for the engine block and gear box, then for the bell housing and casing there was a wire brush on a grinder
#150
Posted 11 May 2013 - 11:20 PM
