Mr Flash - 1992 Standard City
153 replies to this topic
#91 Risky
Risky
  • 213 posts
Posted 18 October 2012 - 07:45 PM
Looking good, 10" wheels and 7.5" brakes are the way to go! I also changed my rear light to MK2 items.... way better!
#92 rob963
rob963
  • Just Joined
  • 350 posts
Posted 23 October 2012 - 12:46 AM
If you suspect water is coming through from inside the door then check to make sure the drain holes (three of them) are clear.
thanks for the tip :proud:
checked them this weekend, all clear, so I suspect the missing check strap seal >_<
Thank you! always nice to get positive comments about my mini from people :D
yeah after i changed to 10''s it made a big difference
and I agree that mk2 rears are awesome! :lol:
#93 rob963
rob963
  • Just Joined
  • 350 posts
Posted 11 November 2012 - 10:13 PM
I thought it would be a good idea to do a 'little' update...
First of all,
The exhaust fitting:
I happened to get the pleasure of using a 2 post lift for this :D
but being silly old me,
I forgot to put slits in the down-pipe before fitting it to the y-peice, so as soon as I took it out for a test drive,
this happened:
so I put some slits in it and fixed it right up :thumbsup:
Since then I have had some intermittent running issues with the car randomly losing power throughout the rev range.
I changed the distributor cap and rotor arm and that certainly improved the situation but didn't solve it..
but then my exhaust decided to separate again, so whilst i had it on stands to fix that, I though I'd see if the ponts were actually opening or not, turns out they weren't so i adjusted them very roughly so that they just closed in the middle of the flat part between the lobes... and guess what?
SOLVED IT! :D
I also decided to change my rocker cover gasket at the same time as the old one was a tad ruined...
before:
after:
finally managed to solve something by myself, I'll still be replacing them when I can but it is running very well now :gimme:
And finally,
this! :shifty:
(obviously except the gauges)
and this:
#94 BrAd2012
BrAd2012
  • 124 posts
Posted 12 November 2012 - 12:41 PM
Way, you finally got a new rocker cover gasket XD the dash board and centre console is looking good. cant wait to see the before and after pictures. would be intresting to see an actually dashh, not the one you made XD XD
Edited by BrAd2012, 13 November 2012 - 12:18 PM.
#95 rob963
rob963
  • Just Joined
  • 350 posts
Posted 12 November 2012 - 06:59 PM
Way, you finally got a new head gasket XD the dash board and centre console is looking good. cant wait to see the before and after pictures. would be intresting to see an actually dashh, not the one you made XD XD
woah, woah, its a rocker cover gasket, not a head gasket... read properly next time! ;D
it certainly does! and I should hope so, was not cheap! >_<
haha very funny, you are funny man. you do stand up now. :shifty:
I know mine is bad, but no need to openly insult me about it... :teehee:
#96 BrAd2012
BrAd2012
  • 124 posts
Posted 13 November 2012 - 12:22 PM
If its cheap, it may not be worth it so :D :D. so i think its money well spent :D :D.
i know, i cant help it :lol: :lol:.
i didnt say it was bad :ohno: lol. I said it would be nice to see a propper dash :proud: :proud:. yours is good, if you want it to look more spartan :shifty: :shifty:
#97 rob963
rob963
  • Just Joined
  • 350 posts
Posted 13 November 2012 - 05:17 PM
Yeah I think it was too :-)
Looks even better in person :teehee:
Hint: that was sarcasm. :-)
Well seeing as you used the word 'proper' I can only assume that you don't think my current dash is a proper dash! If I wanted it to look Spartan, I would take almost everything out! :P
#98 BrAd2012
BrAd2012
  • 124 posts
Posted 19 November 2012 - 10:17 AM
Well ok, "propper" was the wrong word lol. Your getting a custom dash :-) :-) better :-P
#99 rob963
rob963
  • Just Joined
  • 350 posts
Posted 20 November 2012 - 11:32 AM
*proper* :teehee: yeah I know I am, and it is going to look much better :D
So a little update now, decided to have a bit of my christmas present early:
Fits perfectly! And looks awesome :D
will look even better when the dash goes in too, hopefully this weekend :-)
That's all for now, other than that I need new points :(
P.s. I was warned that I may have troubles with room between the console and the clutch pedal, but mine is fine :D
Edited by rob963, 20 November 2012 - 11:33 AM.
#100 BrAd2012
BrAd2012
  • 124 posts
Posted 20 November 2012 - 03:47 PM
Looking awsome!!
May consider getting me one... :shifty: :shifty: as they do look pretty cool :proud: :proud:
You need to get them new points dam it :ohno: :ohno:
Edited by BrAd2012, 20 November 2012 - 03:47 PM.
#101 rob963
rob963
  • Just Joined
  • 350 posts
Posted 20 November 2012 - 05:59 PM
Looking awsome!!
Haha don't go copying me with it! :teehee: but they are pretty cool to be fair... :lol:
Haha I know, need money first. damn bank people.
#102 BrAd2012
BrAd2012
  • 124 posts
Posted 21 November 2012 - 10:34 AM
Well you copied my with the centre clocks lol ;D ;D they sure are =] =]
ok fair enough, but when you get the money, get the points sorted :proud: :proud:
#103 rob963
rob963
  • Just Joined
  • 350 posts
Posted 23 November 2012 - 11:24 AM
I genuinely thought you meant to have the 3 clocks in the middle!
Haha! You can't say anything! You had better be getting that wheel bearing sorted today! :teehee:
#104 BrAd2012
BrAd2012
  • 124 posts
Posted 26 November 2012 - 10:22 AM
i know don't worry, i didn't really make it 100% clear :proud: :proud:.
YH i can, haha, as i HAVE the the part.....i just need the time to do it :shifty: :shifty:
#105 rob963
rob963
  • Just Joined
  • 350 posts
Posted 26 November 2012 - 11:37 AM
I know you didn't! I mis-understood you! :teehee:
Haha time is money, and in your case, possibly destruction of various parts of your car :teehee:
