Winter Workshop 2012 / 2013
154 replies to this topic
#91 millermilla
millermilla
  • 452 posts
  • Local Club: BMC Brighton Mini Club
Posted 15 December 2013 - 01:36 PM
I picked up another complete engine from Southampton. Fingers crossed this one is better than the last.
1468510_10152457101864447_1078783453_n.j
The crank looks spot on and the main bearings look like new. I measured the crank and it is well within tolerance.
1486590_10152457102894447_848611926_n.jp
Piston rings are right at the outside of the tolerance limit so I will be fitting a new set.
1509810_10152457102609447_1674011460_n.j
#92 millermilla
millermilla
  • 452 posts
Posted 15 December 2013 - 01:40 PM
Engine mounts all painted.
1467432_10152452778389447_1497331885_n.j
#93 millermilla
millermilla
  • 452 posts
Posted 17 December 2013 - 09:33 PM
I have removed the yoke for the clutch cable and have converted to a concentric slave cylinder.
1476476_10152463226884447_1456283396_n.j
T piece. The top outlet will have a bleed nipple fitted.
1471760_10152463226854447_641855615_n.jp
I'm replacing all the gearbox gaskets and seals so decided to take a quick look inside and it all looks good.
1482998_10152463227269447_1954588131_n.j
#94 millermilla
millermilla
  • 452 posts
Posted 19 December 2013 - 08:52 PM
Lots of new engine parts so time to start putting it back together at last!
1506456_10152467687869447_138078901_n.jp
Bores refaced ready for new rings
1511352_10152467687659447_2105288770_n.j
#95 millermilla
millermilla
  • 452 posts
Posted 20 December 2013 - 10:15 PM
New piston rings measured and fitted.
1506869_10152470309439447_1594872705_n.j
Bottom end back together
1486794_10152470309589447_2049192143_n.j
Now just for some head work
1510405_10152470309874447_1980573902_n.j
#96 Luke1380
Luke1380
  • 26 posts
Posted 22 December 2013 - 10:45 AM
Really nice project.. Will follow this good job .... Luke
#97 millermilla
millermilla
  • 452 posts
Posted 22 December 2013 - 05:05 PM
Gearbox painted after replacing all the gaskets and seals
1462897_10152472707279447_1257133127_n.j
Head all ready for a rebuild.
New cambelt kit and water pump.
1507672_10152474427854447_881413290_n.jp
It took about 3 goes to get the right angle. Even had to remove the front pulley to give an extra couple of cm's
1508163_10152474428284447_823417712_n.jp
Somehow I managed to get it in without denting the wings
1485072_10152474428259447_272675646_n.jp
All engine mounts on, just need some adjusting
1521860_10152474429024447_678290725_n.jp
Engine looks a bit too high, I'm not sure If I have the lower mount fitted in the right holes. The bonnet does fit and close though with about 1mm clearance.
1514620_10152474429074447_1675317957_n.j
If anyone knows where the mount should go on a 2010 on subframe please shout.
1524863_10152474429764447_1640839204_n.j
I think the exhaust manifold is going to go. The twin pipe one doesn't really fit.
1507126_10152474430124447_871491599_n.jp
#98 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 22 December 2013 - 10:20 PM
Cor you got that in quick!i was expecting weeks and weeks of updates and then it go in.
You don't hang about.
Looks great
Ben
#99 Laundrymike
Laundrymike
  • 27 posts
  • Local Club: Northern
Posted 22 December 2013 - 10:46 PM
Great project and nice attention to detail
#100 jamesmpi
jamesmpi
  • 1,940 posts
Posted 23 December 2013 - 09:08 AM
Excellent project.
Just a thought have to looked through the 16v mini owners forum?
http://www.16vminiclub.com/forums/
They might be able to help answer some of your questions....
#101 silve1999
silve1999
  • 1,146 posts
  • Local Club: MiniFreakz, Brighton Mini Club
Posted 23 December 2013 - 09:15 AM
following thread, very nice work mate, it will be done in no time! looking forward to seeing this beast :-)
#102 millermilla
millermilla
  • 452 posts
Posted 28 December 2013 - 09:40 PM
         I've not updated for almost a week. Xmas kind of got in the way a bit but I've still been very busy but I'm at that stage where the devil is in the detail and the little fiddly bits take hours.
        I've finished all the engine bay wiring now and have had it running for a few seconds with a bit of fuel sprayed in the inlet. I've fitted a single downpipe manifold place of the twin pipe one as it fits with no body mods however I do have a 4 branch manifold coming which I may fit at a later date.
       I bought a new plastic reservoir mini clutch master cylinder which does not clear the manifold when fitted one way round or the brake relocation bar the other way round. The tin master cylinder fits perfectly though.
      Just to give an idea on one of the fiddly little jobs the original crank sensor position only gives about 3mm clearance between the wiring and subframe so I've removed it and twisted it 45 degrees then re-tapped the hole and re-fitted.
1524992_10152491156949447_1364290505_n.j
1535061_10152491157254447_2072453426_n.j
Almost there but still got to plumb the cooling system and choose a radiator and fan.
1003574_10152491157774447_229871623_n.jp
#103 silve1999
silve1999
  • 1,146 posts
Posted 28 December 2013 - 09:45 PM
looks really nice in there, the engine really suits the bay! where are you gonna put the rad and fan? :)
#104 millermilla
millermilla
  • 452 posts
Posted 01 January 2014 - 04:51 PM
I sorted out the exhaust system today, took me all day as it was  aright pain to get right. I used a flexi coupling which I bought new and the rest it all cut and shut off the old Astra system. I've decided the keep the CAT for MOT purposes.
1511290_10152501181349447_1006834150_n.j
1526619_10152501180929447_1148465764_n.j
#105 millermilla
millermilla
  • 452 posts
Posted 02 January 2014 - 09:24 PM
Return to tank fitted. I had to remove the tank and flush out as some swarf from the drill ended up in the tank.
1514487_10152504822054447_1301734129_n.j
New MAP sensor location
1503852_10152504822164447_650696221_n.jp
I found an air filter that fits perfectly. It's a motorbike filter, can't see it being a problem other than that it will need cleaning very regularly.
1501685_10152504822419447_1097455395_n.j
Octane plug location
1533760_10152504822734447_647238466_n.jp
