Winter Workshop 2012 / 2013
154 replies to this topic
#106 DazWood
DazWood
  • 182 posts
  • Local Club: North East Mini Club
Posted 03 January 2014 - 10:38 AM
Its looking refreshed! Great job with the scuttle
#107 lawrence
lawrence
  • 1,341 posts
Posted 03 January 2014 - 01:12 PM
Fantastic budget and then engine conversion build :) slight jealousy from me here!
#108 millermilla
millermilla
  • 452 posts
  • Local Club: BMC Brighton Mini Club
Posted 03 January 2014 - 09:46 PM
The fuel pump arrived today :)
Edited by millermilla, 03 January 2014 - 09:47 PM.
#109 millermilla
millermilla
  • 452 posts
Posted 03 January 2014 - 10:46 PM
Contrary to my previous post about rotating the crank sensor 45 degrees I would not advise this. Luckily I had already wired the OBD socket and the MIL light came on while running and the fault code stored was 19 Crank Angle Sensor (CAS) Incorrect RPM signal. I rotated the crank sensor back to the original position and the fault code cleared.
#110 millermilla
millermilla
  • 452 posts
Posted 10 January 2014 - 10:24 PM
I've decided to go with a standard new MPI radiator as I couldn't find much else that would fit without cutting more of the body away and they were on offer at MiniSport only £65 inc. delivery
1505084_10152524827119447_2106303893_n.j
Next up was to plumb in the clutch. I've used a motorbike brake hose as they are nice, long and braided and it was only £13. It was a right pain to get a seal on the T piece though as it wasn't made for a banjo so there was not much of a flange so I had to file it a bit flatter. I would not recommend fitting the T piece like I did inside the yoke arm housing as it occured to me if the thread strips or I damage the T piece I need to take the box out to replace it! Not a good idea but it's all a learning exercise.
1511108_10152524826969447_563248351_n.jp
Fuel pump and pipes all finished now.
1528642_10152524826944447_493257623_n.jp
Interior back together. Looks very standard!
1496602_10152524827709447_1120644044_n.j
#111 F1L8EY
F1L8EY
  • 600 posts
Posted 11 January 2014 - 11:45 AM
flying along...
how do you get the sped to work accurately wight the standard clocks ??
Filbey
#112 millermilla
millermilla
  • 452 posts
Posted 11 January 2014 - 01:37 PM
I've not driven it on the road yet so I don't know how far it will be out but I've not changed the speedo drive yet so it will be showing faster than actual speed.
#113 millermilla
millermilla
  • 452 posts
Posted 11 January 2014 - 09:14 PM
99 % there now, just missing a couple of pipes before I can run it up properly.
1545056_10152527020844447_646156863_n.jp
#114 silve1999
silve1999
  • 1,146 posts
  • Local Club: MiniFreakz, Brighton Mini Club
Posted 11 January 2014 - 11:27 PM
this is looking really cool
#115 olly33
olly33
  • 758 posts
  • Local Club: 42nd Street (back in day)
Posted 13 January 2014 - 06:52 PM
Just about fitted it all in under that bonnet.Very talented work, i'm impressed.
Wonder what power will be like!
#116 millermilla
millermilla
  • 452 posts
Posted 17 January 2014 - 09:24 PM
Cooling fan switch. I will fit a better connector!
1530385_10152534172774447_1168596831_n.j
Radiator bottom mount
1512698_10152534173124447_931084422_n.jp
Slam panel and bonnet catch trimmed down a bit
1545981_10152534173294447_2071101333_n.j
1526769_10152534173364447_262836315_n.jp
Bottom radiator hose
1016327_10152542139394447_1388008569_n.j
#117 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 17 January 2014 - 11:06 PM
I just love the attention to detail on this build.
Well done!
Ben
#118 BusheyTrader
BusheyTrader
  • Just Joined
  • 481 posts
  • Local Club: Nope
Posted 18 January 2014 - 08:39 AM
Just read from start to finish - great build
Small cars with big engines - love 'em.
Adam
#119 millermilla
millermilla
  • 452 posts
Posted 21 January 2014 - 09:10 PM
Now it's getting near finished I've realised I've now created a right pain of a mini to work on, every inch of the engine bay is needed for something.
It's very nearly finished now. I've had a quick drive up and down the road and it all seems good. Just little jobs to finish now:
Set up steering geometry
Change fan switch for a 95/90 switch
Fit alternator
I made a new bracket for the header tank. It's a bit heavy duty but I figured 1 litre of water bouncing around needs a decent mounting. I've got to say it was a nightmare to make the right shape and angle.
Under the bonnet it's pretty much done. Just need to fit the alternator now.
Both fans work and run on separate relays and the inner wing fan does a really good job of getting heat out of the engine bay.
1521851_10152546650939447_1257946026_n.j
#120 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,041 posts
Posted 21 January 2014 - 09:13 PM
excellent work :highfive:
