image_1362765599995003.jpg 26.89K
9 downloads
Posted 08 March 2013 - 06:35 PM
9 downloads
Posted 08 March 2013 - 06:47 PM
If all you need to do is remove the engine, dealing with brake lines can be more bother than its really worth, which means if it was me, i would lift the engine unit upward instead.
But if its a lot more that needs doing than just the engine, ie, suspension parts, brake lines, subby painting etc, then go for the subby and engine removal from below.
There is no right or wrong really, but just weigh up what you are trying to achieve so you dont end up doing lots more work than necessary, such as reinstating brake lines on the subby, brake bleeding etc.
John
Posted 08 March 2013 - 07:27 PM
thanksSome people prefer to do engine removals by dropping the front subby with the unit, others, like me, prefer to remove the engine through the top. But it all depends on what you are doing.
John
Mini Technical Sections →
Problems, Questions and Technical →
Smith Temp Gauge ModificationStarted by oldman1001 , 06 Oct 2026 |
Clutch Disengagement Issue - Cosworth Bda MiniStarted by cooperbloke , 01 Oct 2026 |
12G202 On A 998Started by Mini30BVA , 28 Sep 2026 |
Engine Surging Then StallingStarted by Adge456 , 06 Sep 2026 |
Stuck Exhaust ValveStarted by JimmyStinkpickle , 28 Jul 2026 |
