Mess Of A Engine! Can't Turn Engine Over
102 replies to this topic
#46 DannyTip
DannyTip
  • 1,020 posts
  • Local Club: A Series Magpies
Posted 03 October 2013 - 06:39 PM
Owch.  Where did you get the engine from? Who 'rebuilt' it?
#47 BlackJester
BlackJester
  • 181 posts
Posted 03 October 2013 - 08:06 PM
Holy sh*t comes to mind lol depending on crank pisyons ect dont look too bsd considering.
#48 Nick Warwick
Nick Warwick
  • 1,588 posts
Posted 03 October 2013 - 08:25 PM
Aaaaand boom goes the dynamite
F911B007-F20E-47B0-9E56-02ED39487189-267
05CCEE83-D127-4BAD-9123-D765C94D0DB2-267
32A4C166-E2A2-4455-81B6-733C091E947D-267
Not naming no names on who built it at the moment, but i am pretty peed off right now because i have been lied to.
#49 cal844
cal844
  • 9,736 posts
  • Local Club: TFMOC
Posted 03 October 2013 - 08:33 PM
ouch!!
#50 MIGLIACARS
MIGLIACARS
  • 2,057 posts
Posted 03 October 2013 - 08:37 PM
name and shame.
has this engine ever run, or is it a fresh build.
did you pay a company to build it.
if you need a crank pm me
#51 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,189 posts
  • Name: Neil
Posted 03 October 2013 - 08:39 PM
The whole thing looks a mess. Not good at all. O_O
#52 Nick Warwick
Nick Warwick
  • 1,588 posts
Posted 03 October 2013 - 08:42 PM
Name and shame will come but not yet.
Engine has never run and has had new big and small engine bearings hmmmmmmm. Cant seem to get the cap off on the crank pulley side even with a gentle tap, one side seems to be locked on the location tab.
Can somebody help me with that bearings i need to buy? Its all new to me
#53 MIGLIACARS
MIGLIACARS
  • 2,057 posts
Posted 03 October 2013 - 08:48 PM
Big ends and main bearing and prob thrusts
You need to measure the journals to see if they have been ground.
if the crank is standard then standard size bearing.
if the crank has been ground 10 then plus 10 bearings and so on.
you will now need to check the crank for marks, if it has marks on the journals it will need grinding assuming it will take a grind.
is it a metro turbo engine.
#54 MIGLIACARS
MIGLIACARS
  • 2,057 posts
Posted 03 October 2013 - 08:51 PM
Is that grease I can see all over the drop gears.
Do you know it has s/c drops
#55 Nick Warwick
Nick Warwick
  • 1,588 posts
Posted 03 October 2013 - 08:53 PM
As far as i know mate the crank is standard but i will make sure.
Yeah its a metro turbo.
I will let you know if i need a new crank, hopefully not!
#56 Nick Warwick
Nick Warwick
  • 1,588 posts
Posted 03 October 2013 - 08:54 PM
Yeah i was told it did have them fitted, supposed to have no grease?
#57 MIGLIACARS
MIGLIACARS
  • 2,057 posts
Posted 03 October 2013 - 09:02 PM
no grease. they run in engine oil.
that would have mixed with hot engine oil and gone all round the engine. when building them build oil is used. not grease.
you need to check the primary gear make sure the bushes are good, front and back.
who s s/c drops are they??????????
what box was used?????
did the same guy build the box??????????/
as it will need looking at.
#58 Nick Warwick
Nick Warwick
  • 1,588 posts
Posted 03 October 2013 - 09:09 PM
Yeah i did think it was strange them being covered in grease, i will get them cleaned up.
Gear box looks fine and standard with just a xpin diff which spins freely, as far as i know the box wasn't rebuilt (fingers crossed)
Just going to measure the crank now.
#59 GraemeC
GraemeC
  • 7,475 posts
Posted 03 October 2013 - 09:37 PM
You'll need to strip the timing gears etc off and remove the two screw behind the crank pulley to remove the main bearing cap at the front of the engine.
Also - it looks like a pre-verto flywheel bolt was used, no wonder it wasn't tight. With the right bolt the socket fitting won't be a problem.
#60 Nick Warwick
Nick Warwick
  • 1,588 posts
Posted 03 October 2013 - 09:48 PM
Ah right didnt know that held the cap in place thanks.
Hahahaha it just gets better and better, is the preverto bolt bigger hence the reason you cant get a socket over it when its close to getting tight due to the flywheel boss?
