Planning on fitting a sump guard that I got for 99p on ebay and a oil cooler, I was just wondering if I got a water temperature gauge with numbers would it be okay to read oil temperature if I used a normal water temp sender in the gear box?
Posted 25 August 2014 - 01:51 PM
Posted 25 August 2014 - 01:58 PM
Can't see why it wouldn't work. Oil temp will be higher than water temp though
Posted 25 August 2014 - 02:11 PM
I realized this would be the case, that's why I thought I would be better of getting a numbers one as they seem to have a higher reading. Proper oil gauges seem a little expensive.
Posted 25 August 2014 - 05:43 PM
Amazon servers me well when buying gauges :)
Hif44 Starter Spindle Seal Fitment IssueStarted by JimmyStinkpickle , 21 May 2026 |
Help Pls! Engine Not Starting, Not Sure What To Do!Started by TheYoungestGary , 08 May 2026 |
Overbored Or Supercharged 850 Rebuild?Started by kkonstantinopoulos , 04 May 2026 |
Su Hs4 CarburettorStarted by Murrayup , 21 Apr 2026 |
Missing Speedo Drive Clamp PlateStarted by JimmyStinkpickle , 18 Apr 2026 |
