New Coil.... Which One?
engine electrical
6 replies to this topic
#1 jcallicott
jcallicott
  • 15 posts
Posted 07 October 2014 - 04:22 PM
I need a new coil but not sure which one to get….
Quite a lot of people use the gold sports coil but I have been looking at the Pertronix coils.
What do people recommend?
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 07 October 2014 - 04:33 PM
All coved in the FAQs electrical , did it only about 2 weeks ago mate,if that helps
#3 cal844
cal844
  • 9,736 posts
  • Local Club: TFMOC
Posted 07 October 2014 - 04:34 PM
What dizzy do you have? (Points or electronic)
What year of car?
Size/ type(A or A+)???
Also on youre current coil is there a pink/white wire?
As above, its covered by KC in perfect detail
Edited by cal844, 07 October 2014 - 04:35 PM.
#4 jcallicott
jcallicott
  • 15 posts
Posted 07 October 2014 - 09:06 PM
Thanks very much,
I know I have a 998cc A+ with ballast resistor  but was just wondering what coils people though were best / most reliable.... Its running electric ignition
Edited by jcallicott, 07 October 2014 - 09:07 PM.
#5 cal844
cal844
  • 9,736 posts
  • Local Club: TFMOC
Posted 07 October 2014 - 09:41 PM
I use a DLB 198(Lucas sport(the gold one)) but i omit the resistor by wiring in a new 12v feed from the fusebox
#6 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 08 October 2014 - 11:50 AM
As Kernow suggested, please read his FAQ on coil selection.
As Cal said, if you are replacing the coil and you have already fitted an (aftermarket) electronic ignition, you no longer need the ballast coil.  Fit a 12V coil and run a new 12V supply wire to it (bypassing the pink/white wire).  Do a little Google searching regarding coil brand reliability... some name brand coils are not as good as you may think.
As a member of this board once wrote "Gold coils are only good for pub points".  His meaning was, if you don't switch to electronic ignition and open the spark plug gap up a bit, having a "performance" coil will not benefit you in the slightest.  If you are not willing to experiment with the plug gaps and then the ignition timing, stay with a standard coil as it will save you money.  The benefit of a performance coil only comes about when you deviate from the factory tuning specs in one area or another.
#7 jaydee
jaydee
  • 8,565 posts
Posted 08 October 2014 - 01:22 PM
Avoid those new Lucas gold coil like the plague, i can only reccomend intermotors coils.
Browse the FAQ section thoroughly, theres anything you need to know about coil selection.
Also tagged with one or more of these keywords: engine, electrical
