Cheers m8, thanks for that.
#166
Posted 30 November 2015 - 05:08 PM
#167
Posted 01 December 2015 - 10:56 PM
Were you ever tempted to buy a heritage shell?
#168
Posted 02 December 2015 - 07:30 AM
Hi DEPS - Yer I was tempted but at over £6500 I couldn't afford that in one chunk. So I gave myself a budget of £250 to £300 a month ordering panels every other month, and I just managed to keep to it
, with the resto going to take place over 2 years. Anyway I've heard some bad reports on the quality of new Heritage shells. Its been a steep learning curve having not done anything like this before. Ive been following a couple of restos on here and that's where I've been getting my training from.
Ger
#169
Posted 02 December 2015 - 11:22 AM
Having purchased a new shell a few years ago I have to say I am very impressed with the build quality. Luckily the price wasn't 6.5K at the time and purposely looked for a car that was beyond saving with a welding torch.
This build is fantastic, keep the pics coming.
#170
Posted 02 December 2015 - 10:58 PM
Ger
Understand that. A little less painful when you are buying things as you go along. Surprising how much you spend though! I was keeping a spreadsheet at the start of mine, but stopped part way through.......probably a good job I did;-)
Also, have new shells gone up in price a lot ? Sure they were about £4k a couple of years ago, but noticed they weird £6.5k now???
Anyway you are doing a fab job. Well impressed.
#171
Posted 07 December 2015 - 07:36 AM
On the w/e I welded the C-Pillars to the rear panel.
Ground down the welds and primed, but will need a skim of filler to tidy them up.
Took off the rear quarter panels so that I could prep the bulkhead and parcel shelf ready for welding.
All ready for next w/e.
Ger
#172
Posted 07 December 2015 - 09:49 AM
#173
Posted 14 December 2015 - 01:32 PM
Busy w/e.
Prepped and welded in rear parcel shelf, ground down welds and sprayed with primer.
Prepped and welded in rear bulkhead, ground down welds and sprayed with primer.
Allready to back on the spit next w/e.
Ger
Edited by ger, 14 December 2015 - 01:33 PM.
#174
Posted 14 December 2015 - 04:04 PM
This is fantastic work.
I may have missed it, but what do you use to get prep the perfect circles around the plug weld holes?
#175
Posted 14 December 2015 - 08:57 PM
http://www.ebay.co.u...=item35f53912d8
Ger
Edited by ger, 14 December 2015 - 08:58 PM.
#176
Posted 14 December 2015 - 09:40 PM
#177
Posted 15 December 2015 - 07:59 PM
Ah OK - they look much neater than I expected a wire brush would do. I was imagining a very small sanding disc which centred in the hole!
i use these too.
when the wear to a certain point, they are hard and compacted so just position the brush in the hole and then drill straight.
#178
Posted 21 December 2015 - 07:36 AM
Not a lot done this w/e but it still took me ages to do.
Yet again the rear quarter panels were put back on - I can now do these in my sleep. and the waist rails welded into place.
Then the panels were taken back off again.
Rear quarters wrer then scuffed up inside and given a coat of primer ready for some top coat before they're fitted.
Then the old girl was put back on the spit.
There should be a big update over xmas.
Ger
#179
Posted 21 December 2015 - 03:33 PM
Looking good, soon to look like a complete mini again at the rear!
Like you I'm also becoming an expert at fitting the rear quarter, I've had the panels on and off a number of times to get it all aligned nicely, I'm ready to get welding on one side and am hoping the other side will be easier (experience will help plus it's not bent through accident damage like the first side was which muddied the waters a little for me).
#180
Posted 21 December 2015 - 04:06 PM
Looking really good I bet it makes life so much easier with that spit doesn't it? so need to invest in one for my next project when the time comes :)
Also tagged with one or more of these keywords: clubman
Projects →
Mini Saloons →
Black 1979 1275GtStarted by StuaR32t , 15 Feb 2025 |
Projects →
Mini Saloons →
Cape Town 🇿🇦 1275HleStarted by JAYO , 28 Feb 2021 |
Projects →
Mini Saloons →
Budget Mini Clubman Shell Restoration For £1500Started by minimissions , 13 Nov 2019 |
Projects →
Mini Saloons →
1275Gt Tarmac Rally Car - From ScratchStarted by KRM_Simon , 26 May 2019 |
Projects →
Mini Saloons →
1275Gt Resto - From Flip To FactoryStarted by Verderad , 12 Mar 2018 |
Bing (2)
