Not Starting
engine electrical
19 replies to this topic
#1 SOW_AUSTIN
SOW_AUSTIN
  • 12 posts
Posted 06 January 2015 - 09:15 PM
Hi,
I have a Austin Mini Mayfair 1988 and it will not start. The starter motor will not turn but occasionally makes a 'CHUNK' noise as if it where wanting to start but doesn't. I have re-charged the battery and tried jump starting and nothing has happened. Any help appreciated.
Edited by SOW_AUSTIN, 06 January 2015 - 09:15 PM.
#2 Carlos W
Carlos W
  • 10,114 posts
Posted 06 January 2015 - 09:19 PM
Check your earths are all clean. Battery to body, and engine to body
#3 SOW_AUSTIN
SOW_AUSTIN
  • 12 posts
Posted 06 January 2015 - 09:29 PM
Where do i locate the earths? thanks
#4 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,034 posts
Posted 06 January 2015 - 09:30 PM
As above check the earths. solenoid?
#5 SOW_AUSTIN
SOW_AUSTIN
  • 12 posts
Posted 06 January 2015 - 09:31 PM
where is the solenoid and what is its job. Thanks sorry first mini :)
#6 Carlos W
Carlos W
  • 10,114 posts
Posted 06 January 2015 - 09:34 PM
There is an earth that runs from the battery to the boot floor. There will also be one from the engine to the bodywork, ensure these are clean where they meet the body and aren't frayed.
Has this problem just started?
#7 alex-95
alex-95
  • 6,034 posts
Posted 06 January 2015 - 09:37 PM
Battery to body is in the boot the short wire from the negitive terminal to the bolt on the boot floor. engine to body is on the engine mount on the left side looking at the engine.
#8 SOW_AUSTIN
SOW_AUSTIN
  • 12 posts
Posted 06 January 2015 - 09:38 PM
I ve had the car since july and had a few problems but none like this. this problem has been like this for the last couple of weeks.
#9 Carlos W
Carlos W
  • 10,114 posts
Posted 06 January 2015 - 09:41 PM
Does jump starting make no difference at all?
#10 SOW_AUSTIN
SOW_AUSTIN
  • 12 posts
What is the solenoid?. thanks
#11 SOW_AUSTIN
SOW_AUSTIN
  • 12 posts
Posted 06 January 2015 - 09:42 PM
No, none at all.
#12 Carlos W
Carlos W
  • 10,114 posts
Posted 06 January 2015 - 09:46 PM
No, none at all.
Ok, have you got a multi-meter?
#13 SOW_AUSTIN
SOW_AUSTIN
  • 12 posts
Posted 06 January 2015 - 09:49 PM
No, none at all.
yes
#14 benm
benm
  • 111 posts
Posted 06 January 2015 - 09:52 PM
tried bump starting it?
#15 SOW_AUSTIN
SOW_AUSTIN
  • 12 posts
Posted 06 January 2015 - 09:54 PM
No, will try that. :)
Also tagged with one or more of these keywords: engine, electrical
