Best Answer NZMini1275 , 08 March 2017 - 06:06 AM
Thought I would give an update.
New distributor arrived from Aldon. It is basically an Aldon yellow with no weights or vacuum advance, as the amethyst unit takes care of that.
The quality is so much higher than the powerspark I had fitted. The Aldon has zero play in the spindle and also the electronic module is far better quality.
The engine runs much smoother so very happy.
Go to the full post
Posted 08 February 2017 - 06:53 AM
Car is nearly ready to hit the road
New engine-Cam has been run in.
Engine specs
1312 cc
Swiftune sw8 camshaft
Minispares mse4 Big valve head
Hif44 carb
Aldon amethyst ignition system
I have a wide band afr gauge and fuel is set to 14-14.5 at idle
Timing is set at 12 degrees at idle
Engine starts easy, idles and revs fine but it vibrates a lot.
Now I haven't had a mini for years and never one with a lumpy cam but I reckon somethings not quite right.
Engine is nicely held with no movement as all steadys and bushes etc are new. Subframe has been solid mounted which I guess makes it worse also.
I'm wondering if the flywheel and clutch could be out of balance.
Would this cause vibrations at idle or only higher up the revs?
Anything else that would cause vibration?
Dan
Posted 08 February 2017 - 07:44 AM
AC Dodd has done some great videos on how far out verto ones can be
Posted 08 February 2017 - 07:49 AM
Is it verto or pre verto?
Its a pre verto and I know they never balanced it or clutch
Posted 08 February 2017 - 09:22 AM
Posted 08 February 2017 - 09:23 AM
Edited by Mini Manannán, 08 February 2017 - 09:23 AM.
Posted 08 February 2017 - 09:29 AM
This is a verto but a pre-verto could easily be the same: https://youtu.be/bQWBcCKpeeE
Thanks mate, that's the one
Posted 08 February 2017 - 09:50 AM
who never balanced it?
the pre verto fly and back plate came balanced as standard.
what have you got?
Posted 08 February 2017 - 09:51 AM
also a video of the engine running would be good.
Posted 08 February 2017 - 09:54 AM
%5BIMG%5Dhttp://i1366.photobucket.com/albums/r776/dangerraty/th_IMG_1834_zpsitvszh86.mp4
%5BIMG%5Dhttp://i1366.photobucket.com/albums/r776/dangerraty/th_IMG_1839_zpskkidnjbl.mp4
Probably have to try a new flywheel and clutch that has been balanced to see if that tames it.
Posted 08 February 2017 - 09:56 AM
Is it running on all 4 cylinders?
Posted 08 February 2017 - 01:07 PM
After doing that, you will know whether it is engine or transmission. It probably is the engine but it would not be good to waste time and money on it if the problem was elsewhere.
Oh, and check that you do have some compliance in the mounts. RUBBER, not poly, in at least one end of the top and bottom steadies.
Then make sure the engine is running properly. Missing a cylinder was suggested above and ought to be the first think to check, followed by valve clearances, timing (check all 4 sparks), carburettor etc. If you have the information necessary and can check your actual camshaft timing by using a dial indicator on the valve gear, that would be useful.
In other words, please check everything external or accessible before assuming that the engine internals are off balance. That may be the case, but it is best to be absolutely sure before stripping anything.
Posted 08 February 2017 - 09:45 PM
It appears to be. All plugs are firing and when I take a lead off one at a time it makes a difference.
Posted 08 February 2017 - 10:10 PM
In case you have not done this yet, you should positively establish whether it is engine or drive train. Does it vibrate with engine running, clutch depressed? Now do the same, in gear, so part of the gearbox including drop gears is locked and not spinning idly due to clutch drag. Now on-road tests, running downhill in neutral, engine off. Then in the appropriate gear for the conditions, clutch down, engine off. (CAREFUL! DO NOT ENGAGE STEERING LOCK!!!)
No difference if clutch is pushed in or if gear is selected.
Should be ready for a run on the road next week
I think engine mounts are all poly so might get some rubber replacements
Will check valve clearances again
I did notice whilst timing that there is a bit of timing scatter.
Posted 09 February 2017 - 12:06 AM
to be honest sounds quite normal.I have a couple of short vids of it running but I would need to get one inside to show how bad it is.%5BIMG%5Dhttp://i1366.photobucket.com/albums/r776/dangerraty/th_IMG_1834_zpsitvszh86.mp4%5BIMG%5Dhttp://i1366.photobucket.com/albums/r776/dangerraty/th_IMG_1839_zpskkidnjbl.mp4Probably have to try a new flywheel and clutch that has been balanced to see if that tames it.
You mention there is some timing scatter that could just be it.
Mini Technical Sections →
Problems, Questions and Technical →
Smith Temp Gauge ModificationStarted by oldman1001 , 06 Oct 2026 |
Clutch Disengagement Issue - Cosworth Bda MiniStarted by cooperbloke , 01 Oct 2026 |
12G202 On A 998Started by Mini30BVA , 28 Sep 2026 |
Engine Surging Then StallingStarted by Adge456 , 06 Sep 2026 |
Stuck Exhaust ValveStarted by JimmyStinkpickle , 28 Jul 2026 |
