What's it like at 1000rpm and 1200rpm?
I think the SW8 could be quite lumpy at a low tick over.
Best Answer NZMini1275 , 08 March 2017 - 06:06 AM
Thought I would give an update.
New distributor arrived from Aldon. It is basically an Aldon yellow with no weights or vacuum advance, as the amethyst unit takes care of that.
The quality is so much higher than the powerspark I had fitted. The Aldon has zero play in the spindle and also the electronic module is far better quality.
The engine runs much smoother so very happy.
Go to the full post
Posted 09 February 2017 - 08:46 AM
Posted 09 February 2017 - 12:27 PM
Posted 10 February 2017 - 09:08 AM
If you have poly engine mounts that will explain a lot. Polyurethane is useful stuff in the right places, which are many, but not engine mounts, ever. It is greatly hyped and knowingly mis-sold by the spivs and wasters who increasingly inhabit the Mini aftermarket where they are finding that they can make a fast buck, for a while.
Posted 10 February 2017 - 09:17 AM
Posted 10 February 2017 - 05:58 PM
Could be. There should be visible movement, a few mm at least, but not more than about 10mm max.
Posted 10 February 2017 - 07:57 PM
My friend Rowan has all the engine steadies money can buy, the 2 lower ones as well as the 2 top mounted, standard engine mounts, everything is very tight and his motor is sooooooo quiet.Thanks to everyone for their inputHave a few things to try and will report back how I get onI'm thinking its the engine steadies as there is zero movement when trying to rock or rev engineThanksDan
image.jpeg 68.21K
18 downloads
image.jpeg 46.54K
16 downloadsEdited by Chris.Williams, 10 February 2017 - 08:01 PM.
Posted 11 February 2017 - 09:26 AM
Engine mounts are rubber so thats not the problem.
Have rubber steady bushes coming.
Today I loosened off the steadys and it made no difference
Going to sneak it onto the road tommorow to see whats its like under load.
Posted 11 February 2017 - 11:23 AM
I have ordered some rubber ones so will swap them out and see how I get on.
Have also ordered a new Aldon dizzy with ignitor. Has no vacuum and no advance weights
This is to work with the amethyst unit. The Powerspark dizzy I have seems bad quality.
Thanks for your input
Dan
my powerspark dizzy was awful i sent it back wouldnt buy one again
and would be no good for your engine after sending my lucas one to AC engine is now great
Posted 11 February 2017 - 11:33 AM
is the crank balanced mine was out
had everything balanced and was worse before engine build
suprised its not balanced with sw8
Posted 11 February 2017 - 12:05 PM
Posted 08 March 2017 - 06:06 AM Best Answer
Posted 08 March 2017 - 05:43 PM
Mini Technical Sections →
Problems, Questions and Technical →
Smith Temp Gauge ModificationStarted by oldman1001 , 06 Oct 2026 |
Clutch Disengagement Issue - Cosworth Bda MiniStarted by cooperbloke , 01 Oct 2026 |
12G202 On A 998Started by Mini30BVA , 28 Sep 2026 |
Engine Surging Then StallingStarted by Adge456 , 06 Sep 2026 |
Stuck Exhaust ValveStarted by JimmyStinkpickle , 28 Jul 2026 |
