I have a 1996 rover mini sidewalk that has been converted to run on twin hs4's rather that the original injection system. The car has a ported head (29mm exhaust, 36mm intake) sports coil and electronic ignition. The problem I am having is that the carbs are horribly unbalanced! I know this because coving the front carburettor has no affect on the engine whereas coving the rear causes it to stall out immediately.
I also had this problem when running the efi as the rear two cylinders ran much richer than the front two. I thought this could indicate a worn out camshaft but after checking the lift with a dial indicator all the intake and exhaust rockers are moving the same amount. One other problem is that when the engine is idling the pistons in the carbs sit so high that the lifting pins do not contact them to help set the mixture. Another thing to note is that whilst the engine is running it will occasionally puff a mixture of fuel and air out of the carbs causing to stumble then idle up temporarily before returning to normal.
Any help would be greatly appreciated!
Thanks, Hal
