Hello,
I've bought a car recently with an Ivor Searle 1380 engine but he hasn't used it much in 5 years so I'm going to do a full service. What are the best spark plugs to get?
Will
Posted 15 April 2017 - 12:46 PM
Hello,
Will
Posted 15 April 2017 - 12:52 PM
Posted 15 April 2017 - 01:21 PM
I'd say BP6ES is where I'd start.. or use BPR6ES if using electronic ignition.
The BP7ES/BPR7ES may be beneficial if running a particularly high compression ratio.
Cam.
Posted 15 April 2017 - 05:13 PM
Hello,
Will
I'd start with a BRP7ES and work back rather than run the possibility of burning the electrode off when you run it under constant hard load.
Posted 16 April 2017 - 01:26 PM
Hello,
Will
Thank you :) I'll get a set of those
Posted 16 April 2017 - 05:30 PM
Use the BPR's if you don't already have supressor leads (or resistor plug caps) fitted.
Mini Technical Sections →
Problems, Questions and Technical →
Smith Temp Gauge ModificationStarted by oldman1001 , 06 Oct 2026 |
Clutch Disengagement Issue - Cosworth Bda MiniStarted by cooperbloke , 01 Oct 2026 |
Turn Signal/indicatorsStarted by oldman1001 , 30 Sep 2026 |
12G202 On A 998Started by Mini30BVA , 28 Sep 2026 |
Engine Surging Then StallingStarted by Adge456 , 06 Sep 2026 |
